IF OR Statement
Can someone tell me what i have wrong with the syntax of this command
IF ((x <> 'ON')or(x <> 'OFF')){do this}
Basiclly i want to do something if x is not equal to on or off.
    xrmichael wrote: »
    it should be:
    IF( X<>'ON' OR X<>'OFF')
      // DO SOMETHING
  • mpullinmpullin Posts: 949
    ericmedley wrote: »
    it should be:
      // DO SOMETHING
    This expression will always evaluate to true!
    You want this:
    if(X <> 'ON' && X <> 'OFF') REBOOT(0);
    or this
    if( !(X == 'ON' || X == 'OFF')) REBOOT(0);
    mpullin wrote: »
    You want this:
    or this
    I wasn't passing judgement on the logic. I was just showing the proper syntax. :D
  • Cheers
    Thanks, back on track again now.
    ericmedley wrote: »
    I didn't see anything wrong with his syntax :(
    Edit: Does OR have to be capitalized? I always use || for logical or and && for logical and.
    mpullin wrote: »
    No, Netlinx is case insensitive
    mpullin wrote: »
    Correct, there wasn?t anything wrong with the original syntax (assuming that x is a char array and not an integer) and the syntax that Eric posted is exactly the same as the original post sans some parens that were doing no harm. As you pointed out, the logic was the problem.
  • DanielDaniel Posts: 9
    It's not OR you need, it's AND...
    if (X is not 'ON') and (is not 'OFF' )
    or if( X <> 'ON' and X <> 'OFF') { // do something }
    with or, it's always true because X will always be "not 'ON" or "not OFF". One of those 2 will always be true so the condition will always fire.
