DirecTV HR-21P Pro Receiver Control
I'm considering RS-232 vs. IR control and don't require feedback from the Rx. I've read the previous threads regarding sleep and lock up issues. Has DirecTV addressed these issues for the DB9 port or does anyone know if it still "sleeps" if using the USB adapter?
The IR port on the back of the unit looks like a 3.5mm stereo headphone jack and is labeled: tip - +5 out; 1st ring - data in; 2nd ring - ground. Seems I would use the 1st & 2nd rings for the 2-wire connection to an IR port on a NI-3100, is this correct? Any update or opinion will be appreciated.
The biggest value I have found to using serial control is for favorite channels. The instantaneous selection of a channel number is a far superior method, in particular if you are using the set top boxes for a distributed music system where there is no TV for on screen display. In addition this provides the ability to highlight which favorite channel is selected. The speed with which a channel is selected and the reliability make this a no brainer for me.
Adam
