Home AMX User Forum AMXForums Archive Threads AMX Hardware AutoPatch Forum
Module Configuration String
I am using a Precis DSP 18x18 for the first time. I am having a little trouble understanding the configuration string for the AMX module. Can someone explain the meaning of the various values in the configuration string?
    viningvining Posts: 4,368
    Try the interface document that's bundled in the workspace:
    Protocol Notes
    • Configuration String Syntax – The Duet module relies on a configuration string to know how to construct itself and all model data structures. A default config string is supplied to the constructor via the NetLinx module stub, but this can be overridden at any time by supplying a new configuration via ‘PROPERTY-<key>,<value>.’ The key and value fields must adhere to the following protocol:
    o KEY: the string ‘config’, case-sensitive
    o VALUE: a string of the following format --
    VM_Name:VM_Num:Ins:Outs:<AMX_TSE || NONE> ?...?=VM_Count
    The last parameter in each VM definition provides a way to explicitly map a VM name onto an AMX SwitchLevel. If a VM does not map directly onto a TSE, then supply the keyword NONE in this location.
    Example:
    AfV:0:12:12:ALL?Video:1:12:12:VIDEO?Audio:2:12:12:AUDIO?Special:3:18:24:NONE?=4
    NOTE: You must call ‘REINIT’ on the module following a call to ‘PROPERTY’ in order for it to realize the new configuration.
    • Feature String Syntax – By default, version 1.2.0 of the Duet module only supports switching operations with respect to the status it asks for and tracks in its model during initialization and refresh operations. If a user wishes for the module to support other features, they must be supplied via ‘PROPERTY-<key>,<value>.’ The key and value fields must adhere to the following protocol:
    o KEY: the string ‘features’, case-sensitive
    o VALUE: a string specifying the features to enable, colon-separated, where the possible values can be one or more of the following case-sensitive arguments:{ gain, volume, tone, balance, eq }. Note that version 1.2.0 will recognize all five of those features, but will only support Gain and/or Volume! The others will simply be ignored, and an error will be logged. If supplying this property to the module, it MUST be followed by a REINIT call in order to take effect.
    glr-ftiglr-fti Posts: 286
    Having looked at that module quite some time ago I gave up trying to figure it out as the protocol is pretty simple and it's easier to create your own. Example to change inputs follows:
    SEND_STRING dvAutoPatchPrecis1,'CI1O18T' // CHANGE output 18 to input 1
    SEND_STRING dvAutoPatchPrecis1,'SO18T' // status of output 18
    Then using the string data_event for the switcher parse the data.
    After reading that explanation and looking at the default config string I realize I don't have a clue either! I haven't read the BCS doc since I wrote my module so maybe if you read that it will start making sense. I use a config string also to set up my module to control up to three 18 x 18's but my config string's explanation is in english.
    CHAR config_value[80] = 'AFV:0:8:8:ALL?Video:1:8:8:VIDEO?Audio:2:8:8:AUDIO?=3'
    a_riot42a_riot42 Posts: 1,624
    wilw410 wrote: »
    There is software that AP has that will configure the string for you.
    Was that just to make me feel dumb since I can't figure that out either! :)
    vining wrote: »
    No. If you feel dumb then there is likely something else going on.
    a_riot42 wrote: »
    You set yourself up for that one Dan and Paul took full advantage. Too funny.
    jazzwyldjazzwyld Posts: 199
    Thought..
    Just out of curiosity why are you using an AMX Module for Autopatch? Would it be much simpler to just write code for it?
    C'mon, I may be dumb but I'm not stupid! That type of response was expected but I would have appreciated a smiley face or something.
    vining wrote: »
    something.
    jazzwyld wrote: »
    I've been debating that one myself ... I have a large project (two actually) using several Autopatches each, and I'm just not seeing where the Duet overhead is worth it. So much of it seems to be for mimicking a mixing board on the touch panel ... all operations I prefer to keep entirely transparent to the user.
    I posted a module in the mopedia section that allows up to 3 Autopatch 18x18's (54 output zones but only 17 inputs) and it has a pretty nice GUI & a GUI for the DSP. I've had very good success with it.
    vining wrote: »
    I have a module too, but mine is entirely stripped down to actually switching and setting levels. As I said, I have no real use for a UI with sliders; I hide all that from the end user.
