Home AMX Technical Discussion
iWeather
I am new to using the whole iWeather thing. I am trying to use it with some thermostats. I have it working, the weather is showing up on the thermostats. I am trying to figure out where I put in the ZIP for the thermostat weather. The weather showing up is close to the weather here, but the forecast is way off. any suggestions?
    bneal wrote: »
    Believe it or not, that feature is disabled on the current version of the module. You have to roll your own. That's what I've done.
    Also, the 'Browse the World/Browse the US' funciton is disabled.
    It's pretty much just set up to make the thermostats work on whatever zipcode you hard-code in.
    Or another way is to get the old version of the module and use it for the non-thermostat i!-Weather stuff. It's not too bad of a memory hog.
