Sticky one - Ideas for an analog clock?
 jp1016
jp1016
                    Hi everyone. I know this one is probaly not worth the work it takes, but anyways, since this week I haven't had anything to do, I was wondering if it is possible to create, somehow, an analog clock on a tp. I know I can draw 60 images to represent the minutes and other 12 to represent the hours, but ain't there an easier way? If I could, somehow, rotate an image, this would be easy. But as far as I know, that is not possible, is it?
Thanks.
                Thanks.
P.S.
You could use something like the scripting in Photoshop to automate making the clock graphics.
I guess if a future revision of TPdesign have a way to draw lines, that could be moved by netlinx code,
this could be much easy, until that, photoshop and Ctrl + T
You could copy some clock example with vista/mac os dashboard and make equal at the TP.
Sure, if I was a little smarter or knew what I was doing at the time it might have been easier but it seems I don't figure out the easy way until I'm done with what I'm attempting and then it's too late.
It involves 2-3 animated faders with 60 steps each. Hours - Miniutes -seconds. I've made it so you can skip the seconds if you wish. The second and minute hand have the spindal graphic. Also, you need to add a button with the back of the clock and if you want a cyrstal (glass) over the clock you have to add another button over the top of all of it.
So if you you're looking at this mess from the side, here are the layers
Crystal
Seconds
Hours
Minutes
Clock Back
Hours are divided up into 60 parts so you'll need to do the math to make that part work.
Minutes and seconds are fairly obvious.
It looks like this when done.
I'll also give you the Photoshop file if you want to make some other clocks or change the size. Good luck exporting the hour/mintue/second hadn stuff. It's boring and a bear...
I may be missing something but is there any reason you can't just make the hour multistate bargraph have only 12 states, then just pass you time info directly to the relevant levels?
On a standard analog clock the hour hand does move between the hours. So for example when the time is 2:30 the hour hand is midway between the 2 and the 3. After viewing my clock I could probably see the purist trying to put more states in since the hour hand seems to jump instead of move more smoothily.
I'll be posting it soon and you all can try it out for yourselves.
I've included all the stuff you'd need to make it yourself to. I made pretty simple clock hands for this sample. It's much easier to create the different positions of the hands in a 3D amination program. But you can do it just fine with Photoshop.
To move the hand from one second/minute just select the layer of the hand and then rotate it by 6 degrees. You'll need to reposition the center of the hand with the spindle. Expoert, wash rinse repeeat...
Be careful not to move the guide layer.
The clock is made with 3 multi-state levels. In this example level 1 is hours. level 2 - minutes and level 3 seconds.
minutes and seconds are simple enough. just send the numberic value of the second and/or minute to the level and it'll work.
Hours is a little more complicated. Here's the formula to make that work. My version doesn't round. I honestly don't care that much. But you may want to round the calculation to get a more honest looking hour hand.
send_level dev_AW_TP_01,3,SECOND_CURR // second hand send_level dev_AW_TP_01,2,MINUTE_CURR // minute Hand if(HOUR_CURR<13) { send_level dev_AW_TP_01,1,(((HOUR_CURR)*60)/12 )+ ((MINUTE_CURR*5)/60) // hour hand } else { send_level dev_AW_TP_01,1,(((HOUR_CURR-12)*60)/12 )+ ((MINUTE_CURR*5)/60) // hour hand }Have fun.
e
PS: Okay, it appears that I cannot upload the file to the website. Must be too big or something. I'll put it on my website.
http://www.ericmedley.com/analog_clock.zip right-click and save as.
ericmedley, I'm changing the background of the clock and all use it on my projects. I liked it very much man. The hard part was to draw the clock's arms, and since you did it and you don't mind we use it, we'll do it =]
Thanks for the effort
Thought that might have been the case. Shows how often I use analog clocks
