Home AMX Technical Discussion
CF Cards for MVP-8400?
Hi there,
Is it possible to use any CF card in the 8400 and is 1GB the technical limit? Or are only the NXA-CFSP.. working?
  • KennyKenny Posts: 209
    technically any CF carf will work but there are a lot timing parameters that need to be met. I'm not what they are. Not sure about the max size.
    There are other msgs on the forum about how to format a cf to work with the MVP.
  • ryanwwryanww Posts: 196
    No, it is not possible to use any CF card in any panel. And unfortunately I don't believe the secret has been discovered to re-sizing a CF card for a panel. From what I know with personal experience is I can take a 64mb card image and copy it to any 64mb or larger card and it will work fine, but only with a size of 64mb. Amx does of corse offer larger cards that they sell, but not sure if they go up that high.
    Ryan
