G3 web control with multiple controllers
Hi,
I've set up a system, using 3 controllers, organized as 3 different systems (each for a different room), each with it's own touch PC, all conneted via IP. Everything works fine, except that on each of the systems, the end-of-session pop-up does not close (although, each when not inter-connected, does close the pop-up).
The 3 systems are inter-connected because they share access to Dynalite and EIB.
As far as I've understood, when the instruction to close the system is sent, the controller does "end", leaving the pop-up "in the limbo", waiting for the info to close down, which never happens).
Any idea why this is happening? It clearly has to do with the fact that all 3 controllers are connected.
JayS
  • RonenRonen Posts: 55
    JayS, can you post the command you are sending from one master to the other to close the popup?
    Is the command to close the popup originating on a master that isn't connected to that panel? You may have to define all the panels on all the masters to make it work.
  • JaySJayS Posts: 9
    Problem solved
    Guys,
    Thank you all for spending a few moments to view my problem, and a particular thanks to those 2 that actually spent a little more answering.
    To solve the problem, I simply substituted the pop-up for a page - was it due to some delay on the ethernet network (dedicated to AMX), including a linksys switch?
    Could it be solved some other way?
    anybody interested in seeing the level of G3 graphics employed?
    JayS
    JayS, did you just replace the "PPOF" command with a "PAGE" command and everything works?
    Can you answer DHawthorne Question?
    Ronen
  • JaySJayS Posts: 9
    Sorry for not having come back sooner.
    Answering DHawthorne:
    No, the command is on the master that is related to that panel.
    don't know if understood - each master has only one (dedicated) web panel.
    It wasn't the command that was substituted, it was the actual graphic pop-up (for a page).
    As mentioned, on all apps. made till this event, with one controller systems, the "end of session" popup has always worked, in this app, even if I only kept one controller in the system, it still didn't work.
    JayS
