PANASONIC TH-50PH11UK && MIO-PRESTIGE S
i am working with a Panasonic TH-50PH11UK LCD and a AMX MIO-PRESTIGE S keypad.
i am having trouble ramping up volume and ramping down volume. it is not repeating. also the feedback light on keypad buttons do not light up.
BUTTON_EVENT[dvKP_229,6]
		SEND_STRING dvLCD2,"$02,'AVL**',$03"					//LCD VOL +
BUTTON_EVENT[dvKP_229,7]
                LCDmute = !LCDmute
		SEND_STRING dvLCD2,"$02,'AMT1',$03"					//LCD MUTE
BUTTON_EVENT[dvKP_229,8]
		SEND_STRING dvLCD2,"$02,'AVL**',$03"			     	        //LCD VOL -
  • JohnMichnrJohnMichnr Posts: 279
    The AMT** command for the display is a command to send a discrete volume level. you would have to send AMT00 thru AMT63 to set the volume to that level.
    A volume up for the Panasonic is $02,'AUU',$03 that will ramp it up one point
    volume down is $02,'AUD',$03
    so one option would be:
    button_event[dvKP_229,6]
      push:
         to[button.input] //feedback
         send_string dvLCD2, "$02,'AUU',$03"
    if you want it to repeat - put in a hold statement
      push:
      hold[1,repeat]
    I like to add one thing so that the button can be pushed once fora single pulse and held longer for multiple pulses:
      push:
      hold[1,repeat]:
        if(button.holdtime>7) //hold the button longer than .7 seconds
    Ditto for the down
    playskool1 wrote: »
    You don't have any feedback commands, depending on how you want your feedback to occur there are many ways to code it, you could just add a TO[button.input] to each push
  • Jimweir192 wrote: »
    got that down.
    now my only issue is controlling the PANASONIC TH-50PH11UK. i checked the AMX NI-3100 and the TX and RX blink together so i know my RS232 control is working fine. is there something i am missing on my command/parameters? the only buttons on the MIO PRESTIGE S Keypad that work are buttons 3 & 4. Button 2, only the audio works but no video.
    BUTTON_EVENT[dvKP_203,1]
    		TO[button.input] //FEEDBACK
    		SEND_STRING dvLCD1,"$02,'PON',$03"					//TURN ON #203 LCD
    BUTTON_EVENT[dvKP_203,2]
    		SEND_STRING dvSWITCHER,"'CL0I1O2T'"					//RACK VCR
    		SEND_STRING dvLCD1,"$02,'IMS:SL1B',$03"
    BUTTON_EVENT[dvKP_203,3]
    		SEND_STRING dvSWITCHER,"'CL0I7O2T'"					//#203 WALL PLATE VGA
    		SEND_STRING dvLCD1,"$02,'IMS:PC1',$03"
    BUTTON_EVENT[dvKP_203,4]
    		SEND_STRING dvSWITCHER,"'CL0I4O2T'"					//#203 RACK PC2
    BUTTON_EVENT[dvKP_203,5]
    		SEND_STRING dvLCD1,"$02,'POF',$03"					//TURN OFF #203 LCD
    BUTTON_EVENT[dvKP_203,6]
         SEND_STRING dvLCD1, "$02,'AUU',$03"
      HOLD[1,REPEAT]:
        IF(button.holdtime>7)                                    //HOLD .7 SECONDS
    BUTTON_EVENT[dvKP_203,7]
    		SEND_STRING dvLCD1,"$02,'AMT1',$03"					//LOCAL MUTE
    BUTTON_EVENT[dvKP_203,8]
         SEND_STRING dvLCD1, "$02,'AUD',$03"
      HOLD[1,REPEAT]:
  • PANASONIC TH-50PH11UK
    i think i figured out the mute toggle using both parameters.
    		IF(nLCD1Mute = 0)
          SEND_STRING dvLCD1,"$02,'AMT1',$03"		//Mute ON
          nLCD1Mute = 1
    ELSE
          SEND_STRING dvLCD1,"$02,'AMT0',$03"		//Mute OFF
          nLCD1Mute = 0
  • doh! fixed. i forgot the Data_Event.
