PANASONIC TH-50PH11UK && MIO-PRESTIGE S
i am working with a Panasonic TH-50PH11UK LCD and a AMX MIO-PRESTIGE S keypad.
i am having trouble ramping up volume and ramping down volume. it is not repeating. also the feedback light on keypad buttons do not light up.
BUTTON_EVENT[dvKP_229,6]
SEND_STRING dvLCD2,"$02,'AVL**',$03" //LCD VOL +
BUTTON_EVENT[dvKP_229,7]
LCDmute = !LCDmute
SEND_STRING dvLCD2,"$02,'AMT1',$03" //LCD MUTE
BUTTON_EVENT[dvKP_229,8]
SEND_STRING dvLCD2,"$02,'AVL**',$03" //LCD VOL -
A volume up for the Panasonic is $02,'AUU',$03 that will ramp it up one point
volume down is $02,'AUD',$03
so one option would be:
button_event[dvKP_229,6] { push: { to[button.input] //feedback send_string dvLCD2, "$02,'AUU',$03" } }if you want it to repeat - put in a hold statement
button_event[dvKP_229,6] { push: { to[button.input] //feedback send_string dvLCD2, "$02,'AUU',$03" } hold[1,repeat] { send_string dvLCD2, "$02,'AUU',$03" } }I like to add one thing so that the button can be pushed once fora single pulse and held longer for multiple pulses:
button_event[dvKP_229,6] { push: { to[button.input] //feedback send_string dvLCD2, "$02,'AUU',$03" } hold[1,repeat]: { if(button.holdtime>7) //hold the button longer than .7 seconds send_string dvLCD2, "$02,'AUU',$03" } }Ditto for the down
You don't have any feedback commands, depending on how you want your feedback to occur there are many ways to code it, you could just add a TO[button.input] to each push
got that down.
now my only issue is controlling the PANASONIC TH-50PH11UK. i checked the AMX NI-3100 and the TX and RX blink together so i know my RS232 control is working fine. is there something i am missing on my command/parameters? the only buttons on the MIO PRESTIGE S Keypad that work are buttons 3 & 4. Button 2, only the audio works but no video.
DEFINE_EVENT BUTTON_EVENT[dvKP_203,1] { PUSH: { TO[button.input] //FEEDBACK SEND_STRING dvLCD1,"$02,'PON',$03" //TURN ON #203 LCD } } BUTTON_EVENT[dvKP_203,2] { PUSH: { TO[button.input] //FEEDBACK SEND_STRING dvSWITCHER,"'CL0I1O2T'" //RACK VCR SEND_STRING dvLCD1,"$02,'IMS:SL1B',$03" } } BUTTON_EVENT[dvKP_203,3] { PUSH: { TO[button.input] //FEEDBACK SEND_STRING dvSWITCHER,"'CL0I7O2T'" //#203 WALL PLATE VGA SEND_STRING dvLCD1,"$02,'IMS:PC1',$03" } } BUTTON_EVENT[dvKP_203,4] { PUSH: { TO[button.input] //FEEDBACK SEND_STRING dvSWITCHER,"'CL0I4O2T'" //#203 RACK PC2 SEND_STRING dvLCD1,"$02,'IMS:PC1',$03" } } BUTTON_EVENT[dvKP_203,5] { PUSH: { TO[button.input] //FEEDBACK SEND_STRING dvLCD1,"$02,'POF',$03" //TURN OFF #203 LCD } } BUTTON_EVENT[dvKP_203,6] { PUSH: { TO[button.input] //FEEDBACK SEND_STRING dvLCD1, "$02,'AUU',$03" } HOLD[1,REPEAT]: { IF(button.holdtime>7) //HOLD .7 SECONDS SEND_STRING dvLCD1, "$02,'AUU',$03" } } BUTTON_EVENT[dvKP_203,7] { PUSH: { TO[button.input] //FEEDBACK SEND_STRING dvLCD1,"$02,'AMT1',$03" //LOCAL MUTE } } BUTTON_EVENT[dvKP_203,8] { PUSH: { TO[button.input] //FEEDBACK SEND_STRING dvLCD1, "$02,'AUD',$03" } HOLD[1,REPEAT]: { IF(button.holdtime>7) //HOLD .7 SECONDS SEND_STRING dvLCD1, "$02,'AUD',$03" } }i think i figured out the mute toggle using both parameters.
BUTTON_EVENT[dvKP_203,7] { PUSH: { TO[button.input] //FEEDBACK IF(nLCD1Mute = 0) { SEND_STRING dvLCD1,"$02,'AMT1',$03" //Mute ON nLCD1Mute = 1 } ELSE { SEND_STRING dvLCD1,"$02,'AMT0',$03" //Mute OFF nLCD1Mute = 0 } } }
