Lamp Info Programming
                    Hello. Firstly please excuse my basic programming knowledge. Can somebody tell me the best way to display projector lamp life hours on a touch panel button, from retrieving the info from the projector to sending the info to the button (in hours.)
I appreciate any tips. Thanks
If you are receiving the information from the projector in hours as an integer. Then just send_command Panel,"''TEXT1-'itoa(projectorHours)". This will display the hours as an ASCII representation of the integer in Address 1 of a button on the Panel.
As for the part about retrieving the info from the projector, that's going to depend on the projector that you're using. It's also going to be a more complex answer because it's going to involve parsing the data that you retrieve from the projector. Do you need to know how to parse the data too, or do you just need to know how to format the commands to send to the projector?
--John
To add to what John wrote, there is a way you can also track this even if the projector doesn't volunteer lamp hours info. (there are several models that do not do this...)
You simply track the time of the on state in the program. Granted, it can get out of sync, but it can be helpful to at least aproximate how old a projector bulb is. You just have to 1) make sure nobody turns on the projector manually and only uses the AMX system ot power it on and off and 2) make sure the technician who changes the bulb knows to reset the AMX system's bulb hours when he/she changes the bulb. It also might be helpful to put an adjustment on the AMX system so a user can correct the time by observing the actual time on the projector's menu.
Many thanks!
If you are having troubles figuring out where to even start writing the code, you might want to contact one of the independent programmers on the forums and hire them to help get you started. I'm sure you could find one that will let you buy the source code for most of what you are asking so that you can refresh your memory on how to code the problem should it need to be changed or done again. Also, keep in mind that if you are just adding to existing code, you don't want to add/change anything that will break the existing code.
Here are some threads that can get you started in learning AMX programming if you haven't run across them yet:
http://www.amxforums.com/showthread.php?t=5147
http://www.amxforums.com/showthread.php?t=5024
http://www.amxforums.com/showthread.php?t=4085
As for the basics of answering your question, the process of querying a device is usually a Send_String command; for Parsing, I would recommend writing a function to handle it. You'll also need to learn about defining devices, creating buffers, online events, data events, variable text, queueing, and string manipulation. If any of these concepts aren't familiar to you then you would really benefit from the programmmer classes. In one of the posts I linked above, forum member Mush gives some really good links for viewable programming reference material too.
If you're not in a rush to get this code ready for a project, then like Spire_Jeff suggested, try writing it and if you get stuck ask questions.
--John
Please don't take this information wrong. Most all of these guys are very generous with their code and information. That's what makes this forum so popular! We understand that you might not be programming systems on a weekly or monthly basis. If you don't use it, you loose it. We are more than glad to refresh what you've already learned. Generally everyone here is very open to providing help and support! Let us know your level in AMX programming.
Whenever I have to program a device, I first check out AMX and ********* for modules. A lot of times AMX has the protocol for the device. Then I google the device for about 15-30 minutes to find protocol. After that I call the manufacturer (generally last because it's time consuming to get a hold of them). At this point you can judge if control of this device is possible with your experience. If you can't do it then spec a different device that you can control or get someone to program a module for you. AMX has a lot of modules for Christie. Check them out to see if one will work for you. I know recently I was looking for a Module for Tandberg C60 but didn't find one so I had to make one myself.
I appreciate the advice anyway, cheers!
