Projector states feedback
Hi!
I want to know if the projector is on,off,warming or coolig, following is a cutout from the duet module interface spesification. I have tried to write this in several ways but it wont work. Could anyone help me on how i should use this to know what state the projector is in.
253
ON: Projector Warming On ? provides feedback only
OFF: Projector Warming Off
Please Note: When channels 253 and 255 are on, then the projector is in warming mode. When channel 253 is off, then the projector is not in warming mode.
254
ON: Projector Cooling On ? provides feedback only
OFF: Projector Cooling Off
Please Note: When channels 254 and 255 are on, then the projector is in cooling mode. When channel 254 is off, then the projector is not in cooling mode.
ON: Set Lamp Power On ? used for feedback also
OFF: Set Lamp Power Off
255 ON: Set Lamp Power On ? used for feedback also
  • kbeattyAMXkbeattyAMX Posts: 358
    Can you show us how you are writing it? The Duet Module is just saying that if the channel is on, that is what state it's in. It's possible for the Lamp state to be on and the projector state may still be warning. You can be sure that if it is cooling the lamp state should be off but the Duet module is saying that Lamp State is actually projector power so the projector power state is on while cooling or warming. I guess you just have to try it out with a projector to see what actually happens with the lamp state.
  • the thing is that i not sure how to use it so i have tried to write the code in different ways. Getting the states and use it as IF's
    one attempt:
    DEFINE_PROGRAM
    [vdvProj,253] = vProjWarming
    Another attempt:
    CHANNEL_EVENT[vdvProj,255]
    ON:
    vProjLampOn=1
    OFF:
    vProjLampOn=0
    CHANNEL_EVENT[vdvProj,253]
    ON:
    vProjWarming=1
    OFF:
    vProjWarming=0
  • John GonzalesJohn Gonzales Posts: 609
    Here's a simplistic way of using the channels to track state. Is this what you're asking?
    vdvProjector	= 41001:1:0
    INTEGER nProjectorStatus //0 = Off, 1 = On, 2 = Warming, 3 = Cooling
    DEFINE_FUNCTION fnUpdateProjectorStatus()
      IF([vdvProjector,254]==1 AND [vdvProjector,255]==1)
    	 nProjectorStatus = 3
      IF([vdvProjector,253]==1 AND [vdvProjector,255]==1)
    	 nProjectorStatus = 2
      IF([vdvProjector,253]==0 AND [vdvProjector,254]==0 AND [vdvProjector,255]== 1)
    	 nProjectorStatus = 1
      IF([vdvProjector,253]==0 AND [vdvProjector,254]==0 AND [vdvProjector,255]== 0)
    	 nProjectorStatus = 0
    --John
  • Thank you=)
