buttons become "on" state automatically
i send my file to master,and i do not push any button .But the button that feedback are chosen "channel" all become "on" state automatically.i don't know why become this .
i use the master is three NI-4100,and use the master to master .for example , 1 to 2 ,1 to 3, 2 to 1,2 to 3 ,3 to 1,3 to 2.This use will bring the problem that i said?? i don't know
anybody has advice.thanks.
Do you have codelines like
DEFINE_PROGRAM
[dvPanel,1] = [1]
[dvPanel,2] = [1]
etc?
These feedbacks are always true, so all the buttons will turn on.
Studio's Code Wizard is creating the feedback lines in this way, to be possible to add and compile them into code. You have to modify these lines for your requirements.
If not, please post a part of your feedback code.
no ,nothing in the define_PROGRAM ,even i send the empty programme,it also will become that.i think
maybe the touchpanel's problem.i use the 5200,the new type of the touchpanel.
when the touchpanel is disconnected the master,the botton is off, but just connect the master the botton will become on immediately and automatically.
If I am reading the above correctly, you have Master 1 connected to 2 & Master 1 connected to 3 but then you have pointed 2 back to one etc, you should only have 1 Master with the other 2 masters in the URL Listing but not on all 3
Hope this helps
Cheers
