Home AMX Resource Management Suite Software
Hello,
I'm just writting my first complete RMS code to interface with my present room code. I am about 80% complete and working to this point. I am however wondering about how to track the useage of a wireless microphone that may or may not be active regardless of the source selected. I also don't want to stop it's useage monitoring when another soucre is selected. Any ideas on the best way to proceed with this?
  • jazzwyldjazzwyld Posts: 199
    Might Help
    Thomas,
    As far as tracking sources, if the source is still on, you can keep it on. I built a wonderful for loop that has helped me with source tracking from room to room. So if you build your system that the mic is a different "room" if one instance of it is on, it will stay on. I know this is very different from your implementation, but keeping track of a source is possible when switching.
    volatile integer RMS_OFF_FLAG[Number_of_Rooms][Number_of_Sources]
    S
    H
    I
    DEFINE_PROGRAM
    for(H=1;H<=number_of_rooms;H++)
    for(S=1;S<=number_of_Sources;S++)
    if(vSOURCE_TO_CONTROL[H]=S)
    on[vdvSources_In_Use,S]
    off [rms_off_flag[h]]
    else
    on[rms_off_flag[h]]
    for(i=1;i<=Number_of_Sources;i++)
    if(
    (rms_off_flag [1]=1) and
    (rms_off_flag[2]=1) and
    (rms_off_flag[3]=1) and
    (rms_off_flag[4]=1) and
    (rms_off_flag[5]=1) and
    (rms_off_flag[6]=1) and
    (rms_off_flag[7]=1) and
    (rms_off_flag[8]=1)
    {off[vdvSources_In_Use,i]}
    Then in RMS Main
    BUTTON_EVENT [vdvCLActions,nchCLSourceTrackerButtons]
    DO_PUSH(vdvSources_In_Use,nchCLSourceTrackerPanelButtons[GET_LAST(nchCLSourceTrackerButtons)])
    CHANNEL_EVENT [vdvSources_In_Use,nchCLSourceTrackerPanelButtons]
    ON:
    ON[vdvCLActions,nchCLSourceTrackerButtons[GET_LAST(nchCLSourceTrackerPanelButtons)]]
    OFF:
    OFF[vdvCLActions,nchCLSourceTrackerButtons[GET_LAST(nchCLSourceTrackerPanelButtons)]]
    Thanks for the idea, I'll give it a try later tonight and test it tomorrow.
