COM 1 not work
Device is NI700
Firmware is 3.30.371
I am trying to send out some string from COM1, the led on front in lighting, but there is no string os SerialWatcher !
When I send same string from COM2 everything is ok , and I can see string in SerailWatcher!
Both ports are set to 9600,N,8,1
Do anyone have some solution ??
Can I put device back to FACTORY DEFAULT ? Will this help ?
Can you post the code your using? Are you using Control a Device?
DEFINE_DEVICE dvPort1 = 5001:1:105 dvPort2 = 5001:2:105 DEFINE_PROGRAM WAIT 10 { SEND_STRING dvPort1,"$02,'04FB',$0D" WAIT 5 SEND_STRING dvPort2,"$02,'04FB',$0D" }That is all that I am using for testing.
@Jimweir192
When you say COM1 and COM2 do you mean on your PC or on the NI700 Port 1 & Port 2
I mean Port 1 & Port 2 on NI700 !
Have you done a DATA_EVENT[device]
and did a send command for the baud rate?
1. Make sure the Device Notification options includes both port 1 and 2 strings out and in.
2. Use a crossed serial cable and connect port 1 to 2, and sending strings across from one port to another ad monitor the outcome.
3. Use a loopback connector (2 shorted with 3) and monitor the outcome on both, observing the difference.
Have you done a DATA_EVENT[device] and did a send command for the baud rate?
Yes, I have
SEND_COMMAND dvPort1,'SET BAUD 9600,N,8,1'
SEND_COMMAND dvPort2,'SET BAUD 9600,N,8,1'
@felixmoldovan
I would use the following troubleshooting method:
All options are checked.
I have try this, but I dontr receive string from Port1 na Port2
Tryed ..... no incoming string on Port 1, in fact Port1 is not sending string at all!!
I have install over 50 controlers, and this is first time that I have problem like this !
Is there option to reset controler to factory default, meabye I have done something with the code, so Port is off or something like that ?
Yes, I have
@felixmoldovan
Yes, I have
@felixmoldovan
Is the AXlink buss clear?
Also, more related to inbound coms, but make sure your DATA_EVENT includes the RXON command. If the port has RXOFF set, then the led will not light.
HTH
No, i am not using AxLink, bus is clear, only one RS232 device is connected for now, and I shoud have two of them.
I can't be sure the electronics are the same in the 700, but if you have a meter, I'd certainly check for the -12VDC (-11VDC) rail.
How to check it ?
Some other thoughts that just crossed my mind...
1. Since you say you are setting the baud in the ONLINE DATA_EVENT, did you check if this effecivelly happens? Meaning...is the device coming online at all?
2. Don't forget about yor one way serial (or even pairing and well pacing two devices on the same port), as an alternative option.
3. I am quite happy with the AMX support, and, if that port is a must, then maybe it's not a bad idea to have it looked at...
Good luck.
You should be very careful doing this! Not sure of your background, but if you slip, you could easily end up with a lot more than a suspect serial port!
Have you put your program in another 700? is it ok?
Being a 700, I doubt it is new, but frankly I would have it checked out by AMX and would not do this rail check unless tech support confirm you are ok to try it on site.
I have service here, try will deal with it.
I have try the same software in another controler, everything is ok.
I have send mail to support in ermany, and waiting for answer.
Good luck!
Did you every find the answer to this? I have the same issue with 2 NI-900s out of 6 and using Firmware 3.30.371 the same as you. It seems like too much data is being received at startup and the port won't accept incoming data until it is unplugged and then replugged. The oddity is it won't show any of that incoming data. I'm going to try a firmware upgrade now. I hope it fixes it.
I tried updating the firmware in my scenerio and it did not work. Although, i discovered if you unplug the serial cable and then plug it in again, the port will then work.
More importantly, the FIX for my problem (after a long long talk with AMX) is to only use a 3 conductor Serial cable. If you're doing RS232 and only need Tx, Rx and Ground, then only use those 3 conductors. I tried this and magically it fixed my issues. AMX said if you use a 9 conductor when all you need is 3, the remaining pins with short with the RS232 pins and cause problems or eventually kill the port. They said if you need 5 pins only, then only wire up a 5 conductor serial cable. (This seems ridiculous but it works)
VladaPub try out a 3 conductor RS232 cable and let me know if that fixes your issues (because it fixed mine).
That is because unlike a PC serial port the Netlinx 9pin connectors are multifuctional - 232/485/422, and in different modes different pins are required. Look on the back panel of any master and you'll find a legend with the pinouts. Wiring up to the wrong pins will at best result in erratic behaviour and at worst could damage hardware. Never use a moulded serial cables!!
I noticed that no one mentioned making sure the Hardware Handshaking is off. SEND_COMMAND dvDevice,'HSOFF'.
Ken, i did HSOFF, RXON, SET BAUD, and all the trimmings (blank program, delayed startup, etc..) and that port would not work with a 9 pin cable. It will always work with a 3 pin. The answer was just use the 3 pin. That was it.
I been programming with AMX for 6 years and this was the first time i ever heard tech support mention to only use the conductors that you need for serial cables on AMX. I would think that info should come with a big red sticker on every new device. "Make Sure to only use the conductors you need or system may become unstable!"
6 years and this is the first time? Wow....I guess you don't do much serial devices as many don't work properly with all 9 pins connected.
I don't do install.
Seems this time an install tech didn't know about the serial cables. And even the times when a molded cables were used in the past, the masters didn't have troubles. The NI-900 seems to be the first device that's been very sensitive to this issue.
http://amxforums.com/showthread.php?t=4085
I'm not saying no other master is affected by this issue, i'm just saying the NI-900s seems to be the most sensitive, because it's the first master that i've found out about this issue with. Heck, when we unplugged the NI-900 and attached the 9 wire cable to an NI-3101 sig series, it worked right away. So i'm just saying the NI-900 seems to show the issue a lot easier. And i know of masters in the field with 9wire cable that have been working for years. So obviously it depends on what kinda of equipment is hooked up. But granted from now on, i'll make sure installers only use the amount of pins needed for each device to avoid future issues. As far as the FAQ, i've never read it, but i will now. I normally only look for things on here i'm having problems with, which isn't very often. Sorry to cause any upsets, i was just surprised i've never heard about this issue for years nor have i had issues with it.
