MVP 7500 won't boot
in AMX Hardware
Hey there guys. I have a problem. I got an mvp 7500 that simply won't boot. It was working properly until last friday - I was almost finishing a project on it. We left it here upon a table, and its battery must have run over during the weekend. Today (monday), we took it to the appartment to finish what we had to do there. We connected it to the power source to load the battery and turned it on again, and it showed the logo screen, but kept stopped there. We tried to take the battery off and put it on again, but it didn't work. We tried to turn it on connected directly to the power source, but the same thing happened. It never went through the logo screen.
Has this ever happened to anyone? Is this panel dead? Or is there something I can do to try to recover it?
Thanks in advance.
Thanks in advance.
[sorry for my lame english]
Is there any danger by doing so?
[sorry again for my lame english]
Yes, that should work, and if you take standard static precautions, there is no danger. I've done it a few times myself quite successfully.
It took me a long time to get to buy the CF Card Reader, but I've finnaly done it. Now I want to use winhex application to restore the image of a working one, but to do that, I have to format the card. Now... It won't work if I do it under Windows, will it?
Which file system does the card have to be formatted to?
WinHex shouldn't need the card formatted to restore an image. The formatting is included in the image itself, it's a bit-by-bit image (or should be).
It would be good to post your solution so any future searcher doesn't simply blow their brains out in frustration.
So I am am now a fan of WinHex, for $60 you can't go wrong, plus you can use Windows to do it instead of Linux, which makes it much easier while on the road.
Hey does anyone have a image for a MVP-7500. I found an old panel laying around our office and when I go to start it up it just hangs on the AMX logo. I'd like to check if it is something easy like this so I can use it to test. Since I am a new programmer it would help a lot.
Karl Griena
karl.griena@avisystems.com
Thanks Again,
Paull
