Video server with CV5 and MVP8400
HI
I would like to use a video server Axis 241Q four channels.
My question is is it possible to get server channel directly?
I would like to create a page on touch panel with four video button(one per server channel) and choose wish cam I want to look.
Somebody can help me on that ?
If your have other solution it will be apreciate
The Axis has the protocol to access any of the channels directly, and also to choose the size, and refresh rate that the stream occurs at. You just need to create Dynamic Image windows that link to these commands, its all an http:// string.
Brad
I'm appreciate
Take a MOXA VPort 2110 for single video and MOXA VPort 2140 for 4 pictures.
It works great.
Somebody can give a cue how I can get pict file on Axis 241S?
Fill out similar to the attached images.
Only one question....
Where you found that info. I spent lot of time in doc and Axis web site to find that without succes...
