Uncomfortably Large Project Size
jjames
I'm doing a job right now that when compiled, the tko file is 1.9mb - the largest I've ever dealt with. I'm assuming it's because of the duet modules. Here are the ones I have in place with count as well:
* (1) AMX_iWeather_Comm_dr1_0_0
* (1) iWeatherUI
* (1) AMX_ENV-VST-C_Comm_dr1_0_0
* (2) AMX ENV-VST-C HVACComponent
* (2) AMX ENV-VST-C ModuleComponent
* (1) FireBall Module v5_0_1
* (3) DirecTV_HR21_Comm_dr1_0_0
* Plus 2 of mine own which track IP, and my weather module - those aren't large at all.
So I have 13 modules total, 11 of them are Duet modules. Here's my transfer info:
Highlighted in red are the ones I'm unsure about. Are they supposed to be that large? Is there anyway I can slim down the size of those? Remote transfers can take quite some time, especially on my DSL connection. This is all a little bit of a shocker because I try to stay away from Duet modules (because of how bloated they are), so I'm just curious: is this typical?
Also, this is my first time implementing the ViewStat modules, so I'm not even sure if I'm defining them correctly - but I think I am.
Any help or info on this would be great!
* (1) iWeatherUI
72057 of 72057 -- AMX_ENV-VST-C_Comm_dr1_0_0.jar 68036 of 68036 -- AMX_iWeather_Comm_dr1_0_0.jar [color=red]1099197 of 1099197 -- devicesdkrt.jar[/color] 149615 of 149615 -- DirecTV_HR21_Comm_dr1_0_0.jar 722 of 722 -- xxxx, 2009-06-08, Rev 0.mf [color=red]1201860 of 1201860 -- PROG.tkn[/color] 600463 of 600463 -- snapirouter.jar 126342 of 126342 -- xxxx, 2009-06-08, Rev 0.src
Do you really need a Duet module for the HR21? The serial/IP protocol gives little advantage over IR, and that could save you some resources right there.
I have kind of a silly rule that I try to follow if possible and only use 4-5 duet modules at most and also try to use non-duet when the option is available.
I know they're supposed to 'actually' run faster than non-duet. At least that's what they said at my PIII - part deaux class last Auguest. I'm a bit skeptical myelf. All I know is that when I've got a bunch of the duet modules running, I can see the slowness creep up on the system's response time.
I have no evidence other than anecdotal at this time, however.
Its loading an entire runtime environment so its no surprise the binaries are much larger. I don't really see it as a problem though. I have one job with 6 Duet (newer) modules running and haven't noticed any problems as of yet. I have found that some of the initial Duet modules available on the AMX website are sketchy, but the newer ones are fine. I guess it depends on who wrote it.
Press eject.
Brag to all of your friends.
Danny
The problem with the 6.x Module is that they totally revamped the interface. I find it more cumbersome to navigate than the ole' 5.x module. I have not noticed anything missing, but the last 2 times I used it was just for FP-1 ipod docks.
It supports the jukebox feature and cover art display on your panel. If you can do without those, it's true v5 will work just fine.
