Uncomfortably Large Project Size
I'm doing a job right now that when compiled, the tko file is 1.9mb - the largest I've ever dealt with. I'm assuming it's because of the duet modules. Here are the ones I have in place with count as well:
* (1) AMX_iWeather_Comm_dr1_0_0
* (1) iWeatherUI
* (1) AMX_ENV-VST-C_Comm_dr1_0_0
* (2) AMX ENV-VST-C HVACComponent
* (2) AMX ENV-VST-C ModuleComponent
* (1) FireBall Module v5_0_1
* (3) DirecTV_HR21_Comm_dr1_0_0
* Plus 2 of mine own which track IP, and my weather module - those aren't large at all.
So I have 13 modules total, 11 of them are Duet modules. Here's my transfer info:
72057 of 72057 -- AMX_ENV-VST-C_Comm_dr1_0_0.jar
68036 of 68036 -- AMX_iWeather_Comm_dr1_0_0.jar
[color=red]1099197 of 1099197 -- devicesdkrt.jar[/color]
149615 of 149615 -- DirecTV_HR21_Comm_dr1_0_0.jar
722 of 722 -- xxxx, 2009-06-08, Rev 0.mf
[color=red]1201860 of 1201860 -- PROG.tkn[/color]
600463 of 600463 -- snapirouter.jar
126342 of 126342 -- xxxx, 2009-06-08, Rev 0.src
Highlighted in red are the ones I'm unsure about. Are they supposed to be that large? Is there anyway I can slim down the size of those? Remote transfers can take quite some time, especially on my DSL connection. This is all a little bit of a shocker because I try to stay away from Duet modules (because of how bloated they are), so I'm just curious: is this typical?
Also, this is my first time implementing the ViewStat modules, so I'm not even sure if I'm defining them correctly - but I think I am.
Any help or info on this would be great!
    ColzieColzie Posts: 470
    Don't know about your specifics, but I have an AMXHome tko that is 4.34MB. Yauwza!
    bcirrisibcirrisi Posts: 148
    My average project runs about 8-10MB.
    jjamesjjames Posts: 2,908
    Alright . . . but there's no way to trim some of that stuff though? Especially the devicesdkrt.jar?
    devicesdkrt.jar is out of your control. It is needed by java modules and from what I have tried, there is no way to avoid sending it. You should be able to tell studio to not send the jar files every time tho, but I seem to have problems where studio is sending the same file twice and telling it to skip sending the file only eliminates one copy from being sent.
    If your Fireball is an SE series or better, you ought to upgrade that module if you can. The current is 6.0.2 or something thereabouts; you won't be able to access the newer features with that one. If it's an E or E2, never mind :).
    Do you really need a Duet module for the HR21? The serial/IP protocol gives little advantage over IR, and that could save you some resources right there.
    Adding Duet Modules almost always make my project's .tko file size go through the roof. I tend to run in the 1-2meg region with most my non-duet projects and 3-10meg with duet depending upon how many modules I use.
    I have kind of a silly rule that I try to follow if possible and only use 4-5 duet modules at most and also try to use non-duet when the option is available.
    I know they're supposed to 'actually' run faster than non-duet. At least that's what they said at my PIII - part deaux class last Auguest. I'm a bit skeptical myelf. All I know is that when I've got a bunch of the duet modules running, I can see the slowness creep up on the system's response time.
    I have no evidence other than anecdotal at this time, however.
    Duet? What? Why?
    a_riot42a_riot42 Posts: 1,624
    ericmedley wrote: »
    Its loading an entire runtime environment so its no surprise the binaries are much larger. I don't really see it as a problem though. I have one job with 6 Duet (newer) modules running and haven't noticed any problems as of yet. I have found that some of the initial Duet modules available on the AMX website are sketchy, but the newer ones are fine. I guess it depends on who wrote it.
    mpullinmpullin Posts: 949
    What do I do if my project size is uncomfortably large for more than 4 hours?
    mpullin wrote: »
    Press eject.
    mpullin wrote: »
    Brag to all of your friends.
    Danny
    ImpaqtImpaqt Posts: 155
    DHawthorne wrote: »
    The problem with the 6.x Module is that they totally revamped the interface. I find it more cumbersome to navigate than the ole' 5.x module. I have not noticed anything missing, but the last 2 times I used it was just for FP-1 ipod docks.
    Impaqt wrote: »
    It supports the jukebox feature and cover art display on your panel. If you can do without those, it's true v5 will work just fine.
