PASSBACK in duet modules doesn't work (w/Duet runtime 1.14.222 )
Recently i have installed Duet Runtime build 1.14.222 (on amx site called NetLinx Studio 1.14.222 SNAPI 1.14 Update).
One annoying bug came out.
Working with Russound CAV6.6 & Marantz CC4001 i have noticed that using "PASSBACK-1" command resolves Event error in Diag and strings from device didn't passthru the duet module.
Error it self looks like this - Line 19 (13:37:53)::SNAPIRouter ERROR: Process event failed! Event data value was nullModuleComponent: Process event failed! Event data value was nullModuleComponent.
Once i have returned version of Runtime/Platform to build 1.10.203 & returned the contents of
C:\Program Files\Common Files\AMXShare\Duet folder back - everything worked like a charm!
I suppose one shouldn't hurry with update of Duet Runtime/Platform for now ?
AFTER returning the Platform/Runtime I receive no Error messages in two duet modules and BEFORE any updatings they also worked perfectly.
I would like if possible to receive opinions of specialists who also faced with such issue or just tryed to switch on PASSBACK function working with Duet Runtime build 1.14.222 .
If PASSBACK- is required and you don't need the new device classes implemented with 1.14, install Environment 1.10.203 again.
