LG TV Channel Tuning
Hi There,
Had anyone program LG TV Channel UP and Down. As per the codes for channel tuning..
EX. Tuning to Channel 35 (analog Cable Channel) codes will be "'ma 00 23 00 00 00 00 01'" which 23 is the HEX equivalent to 35. My question is how would you incorporate if your are going to Channel up and down. Thanks for looking.
cLG_CMDS[][7]= { '' // 1 ,'' // 2 ,'' // 3 ,'' // 4 ,'' // 5 ,'' // 6 ,'' // 7 ,'' // 8 ,'mc 0 08' // 9 POWER TOGGLE ,'mc 0 10' // 10 ZERO ,'mc 0 11' // 11 ONE ,'mc 0 12' // 12 TWO ,'mc 0 13' // 13 THREE ,'mc 0 14' // 14 FOUR ,'mc 0 15' // 15 FIVE ,'mc 0 16' // 16 SIX ,'mc 0 17' // 17 SEVEN ,'mc 0 18' // 18 EIGHT ,'mc 0 19' // 19 NINE ,'' // 20 ,'mc 0 44' // 21 ENTER ,'mc 0 00' // 22 CHANNEL UP ,'mc 0 01' // 23 CHANNEL DOWN ,'' // 24 ,'' // 25 ,'' // 26 ,'ka 0 1' // 27 POWER ON ,'ka 0 0' // 28 POWER OFF ,'' // 29 ,'' // 30 ,'' // 31 ,'' // 32 ,'' // 33 ,'' // 34 ,'' // 35 ,'' // 36 ,'' // 37 ,'' // 38 ,'' // 39 ,'' // 40 ,'' // 41 ,'' // 42 ,'' // 43 ,'mc 0 43' // 44 MENU ,'mc 0 40' // 45 UP ,'mc 0 41' // 46 DOWN ,'mc 0 07' // 47 LEFT ,'mc 0 06' // 48 RIGHT ,'mc 0 44' // 49 SELECT ,'mc 0 5B' // 50 EXIT ,'' // 51 ,'' // 52 ,'' // 53 ,'' // 54 ,'mc 0 1A' // 55 JUMP }Do you know the volume up/down codes.. ??
1) SEND_STRING dv_TV[nIND],"'kf 0 ',ITOHEX(nLG_VOLUME[nIND]),CR"
nLG_VOLUME[] is an (optional) array that keeps track of the volume. This way you know exactly what volume it is at and you can also use it for volume bargraph feedback on your TPs. The syntax is as follows:
2) Use the remote mapping code.
Attached is where I'm getting all of this from & including IR formatting & remote codes for serial, extracted from the owners manual.
