Multiple projector switching using variables?
Good Morning.
I have a classroom with 2 projectors, and need to be able to display multiple sources to each of the projectors at different times. I could create popup pages with different channel source buttons, and have multiple button events for each button unique to each projector, but I would like to be able to send a command to each projector based on which projector is selected on the projector select button.
Confused?
I'm using a module to control the projectors, and all that is working OK, I just want to choose the projector responding to a command with a variable set by a projector selector button. I was thinking of something like this: (I found this code elsewhere on the list, as an example)
dv_proj_1 = 5001:01:0 // proj one
dv_proj_2 = 5001:02:0 // proj two
volatile dev dev_proj_sel[]=
{0,1}
volatile dev dev_projs[]=
dv_proj_1
,dv_proj_2
button_event[dev_TP,1] // power on
push:
local_var integer pj_id
pj_id=get_last(dev_proj_sel)
send_command dev_projs[pj_id],'commence_world_takeover'
Is there a better way, or will this work?
Doug Menke
    I wouldn't use GET_LAST to a button event outside of itself. But your idea is right on . . . try something like this:
    VOLATILE INTEGER nCUR_PROJ;
    BUTTON_EVENT[dv_TP,nPROJ_SEL_BTNS]
    		// Select which project we want to control
    		nCUR_PROJ = GET_LAST(nPROJ_SEL_BTNS)
    BUTTON_EVENT[dv_TP,nPROJ_POWER_ON]
    		IF(nCUR_PROJ) // Send command only if a projector is select
    			SEND_COMMAND vdv_PROJ[nCUR_PROJ],'TAKE OVER WORLD'
    		ELSE // Otherwise send annoying double beep
    			SEND_COMMAND BUTTON.INPUT.DEVICE,"'ADBEEP'";
    Or you could set a DEV variable and set it like so:
    DEV vdv_PROJ_SEL;
    		vdv_PROJ_SEL = vdv_PROJ[GET_LAST(nPROJ_SEL_BTNS)]
    		IF(vdv_PROJ_SEL != 0:0:0) // Send command only if a projector is selected
    			SEND_COMMAND vdv_PROJ_SEL,'TAKE OVER WORLD'
    There are MANY different ways you can do this.
  • Also, you'll need to change
    {0,1}
    to:
    {1,2}
    The 0 will act as a wildcard and will be true for any button pushed during the button event that jjames listed.
    --John
  • Actually you'll need to change the dev_proj_sel[] to a unique set of button numbers or to a unique port on the TP for the button event of the projector selection.
    --John
    I didn't notice this the first time around but you'd need to change your definitions from:
    {1,2}
    to
    volatile integer dev_proj_sel[]=
    {1,2}
    I'll just guess oversight on your part. But John is correct, the zero would act as a wildcard.
    Good luck and let us know how it turns out!
