about iphone connect to master(NI-700)
anyone has used the iphone to control your light system ??
i have some problem about the iphone and the master connect setting.
this is diagnostics message.
Line      1 (11:34:21)::  CICSPTCP Rx connection to 192.168.1.8 has been closed locally or by peer
Line      2 (11:34:21)::  Memory Available = 9074680 <37696>
Line      3 (11:34:52)::  CICSPTCP Rx connection to 192.168.1.8 has been closed locally or by peer
Line      4 (11:35:24)::  CICSPTCP Rx connection to 192.168.1.8 has been closed locally or by peer
Line      5 (11:35:55)::  CICSPTCP Rx connection to 192.168.1.8 has been closed locally or by peer
Line      6 (11:36:26)::  CICSPTCP Rx connection to 192.168.1.8 has been closed locally or by peer
master's ip is 192.168.1.29.i use the 'AMX_Module_REV02' and i don't know how to set the
dvMaster_1 =     0:01:0 (* NETLINX MASTER                               *)
RS232____1 =  5001:01:0 (* 		                    NI-RS232    *)
RS232____2 =  5001:02:0 (* 		                   NI-RS232    *)
dvRelais_1 =  5001:08:0 (*                                  NI-Relais   *)
dvIR_____1 =  5001:09:0 (* 		                    NI-IR       *)
dvIO_____1 =  5001:17:0 (*                                  NI-I/O      *)
dviPhone_1 =     0:02:0 (* iPhone TP Device                 iViever     *)
dvTP__2__1 = 34001:01:0
how can i define a real iphone device
my iphone's ip is 192.168.1.8 and in my iphone setting 'CF iviewer' the 'File URL' is 'http://192.168.1.237:8020 ',but when i use the CF iviewer on my iphone will get a Warning message like"Experiencing intermittent connection loss"
my computer's ip is 192.168.1.237 and use the 'CommanFusion guiDesigner' that i set the 'project properties'--'control system'--'Ip Address' is 192.168.1.29 and 'port' is '1319'.
does anyone have ad ,thanks a lot.
  • I use virtual keypad and my iPhone works just fine. Are you having issues connecting when outside of your home network? Have you checked on services that make your private IP public?
  • wgqkakawgqkaka Posts: 16
    Thanks.But i want to use the commandfusion software,and try to make connection between iphone and master, i failed.hopes your help
    thank you
