Biamp Audia Teleconferencing
i am trying to create a teleconferencing page on a touch panel and i want to create a keypad dialer layout. i already created the TPD4 for it but i am unsure about the Biamp Protocols on what to use for entering the 0-9 dialer buttons and * and #. would this be possible and has anybody tried it?
...assuming your telephone interface is in unit 1, and your dialer block has 'dialer' as its instance tag. Substitute '0' through '9' or '*' for '#', as needed, or use an entire phone number to dial it all in one go, e.g.
You could also use the raw instance number instead of the tag, but tags totally rule.
All of this is available in the Help for the Biamp Audia software, and I think they recently made it available as a standalone document on the website.
PS - you will probably also want a "mic mute" function.
Hell yeah. You'll need recent firmware/Audia software to use tags though.
Biamp has protocol documents for its products on the website which are essential reading if you're trying to control them.
