IO ports on a NI-700/900
Hi there,
I've always been using the IO ports for input only, i.e. by connecting potential free output contacts of a relay and this works great. As the NI-700 and NI-900 don't have relay outputs, I thought I ask how people use them as outpus? There is already a +12v out with them, can a relay be connected? Anyone have a schematic handy?
This configuration is often referred to as "open collector" if you would like to research it further.
An electronic relay uses a semiconductor to to complete the circuit to your controlled load. Generally the control side of electronic relays is very high impedance, meaning it requires almost no current to activate the relay.
A while back I went on a soldering kick and built a bunch of 2 relay boards from kits. Worked out to be relatively inexpensive -- $10 to $15 each. Also, someone here posted a link to a supplier who sold multiple relay boards on a big PC board and you could cut off as many relay boards as you wanted. Interesting concept and if I recall correctly, it came out to not much money per relay. These, if I'm not mistaken, also had "diode protection." I thought it was Dave Hawthorne who had recommended these multi board relay boards, but I haven't been able to find the post that mentioned them -- perhaps I'm mistaken.
EDIT:
Well, I searched a little more and found a previous thread about the use of IO ports. Two very nice posts (among others):
Vining posts about how to wire up discrete relays using a diode for protection. Note that in the diagram he posted that the "transistor" serves the purpose of the IO port. If you look at that diagram, it's essentially the same as the diagram that Bob posted in this thread. See: http://www.amxforums.com/showpost.php?p=23842&postcount=24
Also, see Dave Hawthorne's post about the Altronix RB610 which includes six separable relay boards. A quick google search indicates that these things are available for $30 or less, which comes out to not much per relay. See:http://www.amxforums.com/showpost.php?p=23859&postcount=28
I'll post a message to that thread to bring it to the surface.
Jimmy
The following is an ultra-low current relay that should work well with an I/O port. (Disclaimer: This is not an AMX endorsement for any product, just a personal favorite. Use at your own risk.)
http://www.elkproducts.com/products/elk-924.htm
