CBUS Module
Has anyone used the new clipsal 50131rdtsl temp sensor in temp broadcast mode with the cbus module, We are getting data back from the module but cannot convert it to the real room temperature. A typical string back from the unit is RX FROM CBUS= K:G:[00:19:04]:55, but the KG response it documented in the cbus amx notes.
Any help greatly appreciated. Michael
  • so does the 55 mean anything?
    i assume that the first six numbers are the NW:AP:GA, so is 55 the degrees in Fahrenheit?
  • CBUS
    You got me going in the right direction its 55 hex convert to dec 85 / 4 to get the temp 21.25 degs. Cheers for the response, not many people seem to use cbus.
  • no worries! working on a big project that happens to use it right this very moment :-)
