IR Basics
Hi
I went on the P1 course a few months back. The time has come to do my first project. I have the rs232 control that I need working. Its now time to do the IR. I have located the IR database which I need and mapped it to the port. Do I have to define the constant number relevant to what number it is in IR EDIT? this is the code I have then written. Is this the right way?
DEFINE_CONSTANT
//denon amp
denon_onoff = 9
denon_volume_up = 24
denon_volume_dwn = 25
//denon button events
button_event[dvtp,28]
button_event[dvtp,29]
switch(button.input.channel)
case 28: pulse[dvIRAMP,denon_volume_dwn]
case 29: pulse[dvIRAMP,denon_volume_up]
On notifications I can see that the button I press is activating the correct channel, but it doesnt seem to be sending an IR signal out.
Any pointers would be helpful
Dave
DEFINE_CONSTANT
//denon amp
denon_onoff = 9
Dave
button_event[dvTP,nDVDbuttons] { push: pulse[dvDVD,DVDmap[get_last(nDVDbuttons)] }This allows you to use the same buttons over and over again. Just modify the map for different Models of DVD.
