Negative Integers
DATA_EVENT[dvAUDIO_SWITCH]
STRING:
STACK_VAR CHAR sMYBUF[50]
STACK_VAR INTEGER nSTRING_LENGTH
STACK_VAR INTEGER nAUDIO_SWITCH_OUTPUT
WHILE(FIND_STRING(sAUDIO_RXBUF,'SL2',1)) // WHILE THE MESSAGE IS A STATUS UPDATE
REMOVE_STRING(sAUDIO_RXBUF,'SL2',1)
sMYBUF = REMOVE_STRING(sAUDIO_RXBUF,')',1)
IF(LEFT_STRING(sMYBUF,1) == 'O')
GET_BUFFER_CHAR(sMYBUF)
nAUDIO_SWITCH_OUTPUT = ATOI(LEFT_STRING(sMYBUF,1))
REMOVE_STRING(sMYBUF,' ',1)
nSTRING_LENGTH = LENGTH_STRING(sMYBUF)
sMYBUF = LEFT_STRING(sMYBUF,(nSTRING_LENGTH - 2))
sAUDIO_SWITCH_VOLUME = sMYBUF
IF(FIND_STRING(sAUDIO_SWITCH_VOLUME,'M',1))
nAUDIO_SWITCH_VOLUME[nAUDIO_SWITCH_OUTPUT] = -700
ELSE IF(FIND_STRING(sAUDIO_SWITCH_VOLUME,'-',1))
nAUDIO_SWITCH_VOLUME[nAUDIO_SWITCH_OUTPUT] = (ATOI(RIGHT_STRING(sAUDIO_SWITCH_VOLUME,(nSTRING_LENGTH -1))) * (-1))
ELSE
nAUDIO_SWITCH_VOLUME[nAUDIO_SWITCH_OUTPUT] = ATOI(sAUDIO_SWITCH_VOLUME)
REMOVE_STRING(sMYBUF,LEFT_STRING(sMYBUF,nSTRING_LENGTH),1)
fnAUDIO_SWITCH_VOLUME_UPDATE()
Why if sAUDIO_SWITCH_VOLUME is '-150' does my integer nAUDIO_SWITCH_VOLUME[] store as 65386 instead of -150? I know that 65386 - 65536 = -150 but I don't get why it is storing info that way. nAUDIO_SWITCH_VOLUME is defined as an sinteger.
http://en.wikipedia.org/wiki/Two's_complement
--D
This is my variable declaration and I'm still getting issues.
I actually don't believe that I've ever seen the debugger show a negative number for a sinteger. If there's a way to do that, I'll be very happy.
DATA_EVENT[dvREF_70] { ONLINE: { SEND_COMMAND dvREF_70,"'SET BAUD 9600,N,8,1'" } STRING: { SEND_COMMAND dvTP_REF_70,"'^TXT-1,0,',DATA.TEXT" IF (MID_STRING(DATA.TEXT,5,1) == 'R') // IF STRING IS A STATUS MESSAGE { ON[nRECEIVE_STRING] nVOL_1 = TYPE_CAST(HEXTOI(MID_STRING(DATA.TEXT,17,1))) nVOL_2 = TYPE_CAST(HEXTOI(MID_STRING(DATA.TEXT,18,1))) nBK_VOLUME = ((16*nVOL_1) + nVOL_2)-96 // SET UP POLLING SO THAT VOLUME NUMBER IS ALWAYS ACCURATE IF (nBK_VOLUME <= 0) // NEGATIVE OR ZERO VOLUME { sBK_VOLUME = ITOA(nBK_VOLUME) } ELSE // POSITIVE VOLUME { sBK_VOLUME = "'+',ITOA(nBK_VOLUME)" } SEND_COMMAND dvTP_OFFICE_REF_70,"'^TXT-2,0,',sBK_VOLUME" SEND_COMMAND dvTP_REF_70,"'^TXT-2,0,',sBK_VOLUME" } ELSE { OFF[nRECEIVE_STRING] } } }
