Need to send a string to a device at regular intervals
I need to poll a projector for lamp status on a regular basis, but nothing I try seems to work.
I tried a WAIT in the runtime loop, and nothing happens.
I tried the following code in the runtime, and nothing happens:
IF (TIME='??:??:?0') // Execute every 10 seconds
WAIT 11
SEND_STRING dvVideoProjectorIP,"'TLPS 1',13"
  • HedbergHedberg Posts: 671
    Most people will probably tell you that the preferred thing to do is to use a timeline.
    However, you can do it in define program, there's nothing wrong with that if that's what you want.
    Looks like you are trying to send the string every 11.1 seconds. Try this:
    WAIT 111
    This will not start a new wait each time define_program runs, even though it might look like it will. Waits will not "stack" when encountered repeatedly in define_program or in functions, subroutines, or events.
    Now, as for your
    this: '??:??:?0', is a string literal. You are not using wild card characters, you are using question mark characters. I don't believe wild cards work within Netlinx programming. Look in the Netlinx documentation for various string parsing functions such as LEFT_STRING, RIGHT_STRING, MID_STRING to see how to extract a character from a particular expression.
    Hedberg wrote: »
    Check out COMPARE_STRING(). I'm not sure of the overhead involved, but it does allow wildcard searching, but not the multicharacter wildcard (*).
    Spire_Jeff wrote: »
    Ok, that's one I've not used.
    Instead of
    we should have
    IF (COMPARE_STRING(TIME,'??:??:?0'))
    Or, could use RIGHT_STRING (or other functions)about as easily.
    Or you can use the built-in functions like:
    TIME_TO_SECOND(TIME)
    instead of the string parsing.
  • If you just want to send a string to a device at regular intervals just do this:
    Define_Program
    wait 10
    //poll the device
  • PhreaKPhreaK Posts: 966
    I think you may have to name the wait for it to work.
    PhreaK wrote: »
    It will work the same with or without the name.
    By naming the wait you can manipulate it but it still works the same.
    Joe Hebert wrote: »
    My bad.
    This post is at least 10 characters.
  • dmenkedmenke Posts: 25
    Thanks for all the ideas and help. I'm not sure how, but the WAIT I put in the runtime loop started to run. It's all good now.
    Doug
