MET-ECOM Relay Ports
in AMX Hardware
Quick (and possibly dumb) question. On the MET-ECOM physical unit, the relays are numbered from left to right looking from the back of the unit. That is, relay 1 is on the left, relay 2 is on the right. This is what the sticker under the connector says.
However, in the manual, it shows relay 2 on the left, and relay 1 on the right.
Which one is correct?
Chuck
Chuck
What do you plan on using the relays for IYDMMA?
