? RS232 Module for Panasonic Profesional Plasma Display PF-series
Hi there,
anyone has a Module to control over RS232 the Panasonic Professional Plasma Displays, like TH-50PF10, TH-65PF10, TH-103PF10? Please drop me a line. Thanks much in advance!
--John
PROGRAM_NAME='MBR Main' (***********************************************************) (***********************************************************) (* FILE_LAST_MODIFIED_ON: 12/29/2008 AT: 13:28:02 *) (***********************************************************) (* System Type : NetLinx *) (***********************************************************) (* REV HISTORY: *) (***********************************************************) (* $History: $ *) (***********************************************************) (* DEVICE NUMBER DEFINITIONS GO BELOW *) (***********************************************************) DEFINE_DEVICE (* REAL DEVICES *) dvTVMBR = 5001:1:0 (* VIRTUAL DEVICES *) vdvTVMBR = 33001:1:0 (***********************************************************) (* CONSTANT DEFINITIONS GO BELOW *) (***********************************************************) DEFINE_CONSTANT (***********************************************************) (* DATA TYPE DEFINITIONS GO BELOW *) (***********************************************************) DEFINE_TYPE (***********************************************************) (* VARIABLE DEFINITIONS GO BELOW *) (***********************************************************) DEFINE_VARIABLE INTEGER nDebugMBRTV INTEGER bBusy (***********************************************************) (* LATCHING DEFINITIONS GO BELOW *) (***********************************************************) DEFINE_LATCHING (***********************************************************) (* MUTUALLY EXCLUSIVE DEFINITIONS GO BELOW *) (***********************************************************) DEFINE_MUTUALLY_EXCLUSIVE (***********************************************************) (* SUBROUTINE/FUNCTION DEFINITIONS GO BELOW *) (***********************************************************) (* EXAMPLE: DEFINE_FUNCTION <RETURN_TYPE> <NAME> (<PARAMETERS>) *) (* EXAMPLE: DEFINE_CALL '<NAME>' (<PARAMETERS>) *) (***********************************************************) (* STARTUP CODE GOES BELOW *) (***********************************************************) DEFINE_START nDebugMBRTV = 0 (***********************************************************) (* THE EVENTS GO BELOW *) (***********************************************************) DEFINE_EVENT DATA_EVENT[dvTVMBR] { ONLINE: { SEND_COMMAND dvTVMBR, "'SET BAUD 9600,N,8,1'" } STRING: { IF(nDebugMBRTV) SEND_STRING 0, "DATA.TEXT" } } CHANNEL_EVENT [vdvTVMBR,0] { ON: { SWITCH(CHANNEL.CHANNEL) { CASE 24: {WAIT 5 SEND_STRING dvTVMBR,"$02,'AUU',$03" //Volume Up } CASE 25: {WAIT 5 SEND_STRING dvTVMBR,"$02,'AUD',$03" //Volume Down } CASE 26: SEND_STRING dvTVMBR,"$02,'AMT', $03" //Mute Toggle CASE 27: SEND_STRING dvTVMBR,"$02,'PON', $03" //Power On CASE 28: SEND_STRING dvTVMBR,"$02,'POF', $03" //Power Off CASE 56: SEND_STRING dvTVMBR,"$02,'AMT:1', $03" //Mute On CASE 57: SEND_STRING dvTVMBR,"$02,'AMT:0', $03" //Mute Off CASE 81: SEND_STRING dvTVMBR,"$02,'IMS:SL1', $03" //Input SL1 CASE 82: SEND_STRING dvTVMBR,"$02,'IMS:SL2', $03" //Input SL2 CASE 83: SEND_STRING dvTVMBR,"$02,'IMS:SL3', $03" //Input SL3 } } } (***********************************************************) (* THE ACTUAL PROGRAM GOES BELOW *) (***********************************************************) DEFINE_PROGRAM (***********************************************************) (* END OF PROGRAM *) (* DO NOT PUT ANY CODE BELOW THIS COMMENT *) (***********************************************************)Minimum time between commands is 250ms, TV doesn't respond for up to 15 seconds after a power command is issued, and the cable is straight thru 2,3,5
--John
