Relay Box Hex Codes problem
I am trying to control a Relay Box that uses 232, but I'm having a problem with sending the correct code structure, I think. The device's protocol guide shows the following settings need to be made on my controller:
Configure port as 4800 bps N-8-1.
So I've done this:
First byte = header (40h)
Second byte = address (01h - FEh)
Third byte =
Zone number (1 ? 8) in lower nibble and
Command (3 = ON & 4 = off) in upper
Example (all 3 bytes) for module address 1:
zone1 on = 40 01 31 (hex)
zone1 off = 40 01 41 (hex)
So I read that to mean that I need to send 40 01 31 in hex to the device. Here is what I have in my button presses:
So I've done this:
DATA_EVENT[dvRelay] //data event for rs232 relay8net control box
ONLINE:
SEND_COMMAND dvRelay, "'SET BAUD 4800,O,8,1'"
For the actual command structure, the protocol guide says this:First byte = header (40h)
Third byte =
BUTTON_EVENT[dvTp,40]
nShadeStatus = 1
SEND_STRING dvRelay, "$40,$01,$13" //turns relay 1 on
Wait 5 'relay 1 on'
SEND_STRING dvRelay, "$40,$01,$14" //turns relay 1 off
I don't know if it's a problem with the processor not sending commands at the right speed, or if my interpretation of how to send the codes I want is incorrect. help? Is there a place in NS3 to verify the port settings on the controller? 0
It should be:
You can verify port settings by enabling notifications for the device (set your notification options first.)
Then use 'Control a Device' to send the port the GET BAUD command. The ports settings will show up in the notifications window.
DATA_EVENT[dvRelay] //data event for rs232 relay8net control box { ONLINE: { SEND_COMMAND dvRelay, "'SET BAUD 4800,N,8,1'" } STRING: { sRelayStatus = DATA.TEXT SELECT { ACTIVE(FIND_STRING(sRelayStatus, '$40,$01,$31',1)): { nShadeStatus = 1 SEND_COMMAND dvJVCLT37X898Tp, "'^TXT-46,0, Relay 1 is ON'" } ACTIVE(FIND_STRING(DATA.TEXT, '$40,$01,$41',1)): { nShadeStatus = 1 SEND_COMMAND dvJVCLT37X898Tp, "'^TXT-46,0, Relay 1 is OFF'" }I am running into an issue where I can see the feedback response / string value of 40,1,41 (in the watch bar when I have the display type set to hex) which is the box saying that zone 1 is off, but the response is in hex, just like the commands I send. I have tried leaving the $ in place as well as removing it, but to no avail. Is this an issue of the unit sending hex back, and the find_string function not being able to search for hex? The protocol guide says this:The response of the Rain8 is to execute any command then send back the same three bytes as an ACK.
Try this instead:
BUTTON_EVENT[dvJVCLT37X898Tp,41] //CLOSE { PUSH: { If (nShade1Status = 1) { CANCEL_WAIT 'relay 1 on' SEND_STRING dvRelay, "$40,$01,$41" } SEND_STRING dvRelay, "$40,$01,$32" Wait 50 'relay 2 on' SEND_STRING dvRelay, "$40,$01,$42" } }The problem I have is this: If the lift is going up and I press down, the open ( or up) relay opens (which is good), but the close (or down) doesn't trigger. When the IF statement is not true, each relay works as it should. Will the IF statement not work in this situation?BUTTON_EVENT[dvJVCLT37X898Tp,41] //CLOSE { PUSH: { If (nShade1Status = 1) { CANCEL_WAIT 'relay 1 on' SEND_STRING dvRelay, "$40,$01,$41" } wait 2 SEND_STRING dvRelay, "$40,$01,$32" Wait 52 'relay 2 on' SEND_STRING dvRelay, "$40,$01,$42" } }
