Comcast/Pace RNG110 IR Codes...
Does any one have an irl file for the Comcast RNG110 Cable Box? I learned the codes with a Pronto, and cut and paste them into IR Edit, but they do not work... They do however work on the Pronto...
I tried learning the codes with the IRIS, but every other code states that a duplicate code was found.
Help please....
Regards, Eric
    I don't know if this will work with that particular model; I suppose it's worth a try. I've used it on other Comcast boxes.
  • Thanks...
    DHawthorne wrote: »
    I will give it a try... Thank you, Eric
    Is this the Cisco box?
    DHawthorne wrote: »
    Those won't work. I haven't found any codes that will work with these boxes. Stealing IR from the remote with AMX Iris didn't work either. I had a client return them for the older Motorola boxes.
