MVP-8400 Factory Defaults
I've disabled front button setup access on my panel. Is there a way to reset to factory defaults?
Greg.
  • HedbergHedberg Posts: 671
    You can put the TP in setup:
    send_command dvTP,'SETUP'
  • etranetran Posts: 5
    If I had a network connectivity with the panel I could telnet and pop up the setup page. But, I don't have it. My wireless network config is messed up. There has to be a way to reset the MVP to factory default, as I can bring up the setup page by pressing the front buttons????????
    Please help,
    Thanks.
    Greg.
    etran wrote: »
    Hold your finger down on the screen while the panel is rebooting and it will take you to the setup page. If you hold down even longer it will take you to the calibration page.
    It took me a couple of tries to get to the setup screen. Obviously I don?t know much about the AMX. Thank You very much for help.
    Greg.
    Glad you got it working. Have fun.
