Just Add Power HDMI over IP module for AMX now available
Just Add Power launched the HDMI over IP solution into the public eye at CEDIA in September. You can watch a YouTube demonstration of the HDMI over IP solution on the homepage of www.justaddpower.com . Since the big exposure at CEDIA, we have had several dealers working on writing drivers for specific home automation solutions. I am very happy to announce that we now have a Right Sized HDMI Matrix AMX module ready for sharing with the AMX community. I've attempted to attach the module to this thread, but you can directly request a copy of this module by sending an email request to support at justaddpower dot com. I am also expecting that this module can be posted in the shared publich module area of this forum.
I will suscribe to this thread and be happy to answer any questions about HDMI over IP and how it can be used with AMX technologies to implement a Right Sized HDMI Matrix.
Ed Qualls
Just Add Power
  • NdedNded Posts: 11
    The AMX dealer that wrote this driver for HDMI over IP is really hoping to get some feedback on how to improve on his work. Does anybody that has downloaded the example driver have any comments or suggestions on how to improve on this design?
    This looks interesting. So in the simple scenario of using a isolated Catalyst Switch to connect the various receiver & transmitters how to the receivers choose the tranmitter to source? Just open a connection to a receiver and tell it which transmitter to connect to? How many connected clients can each transmitter support? I saw the krestron key reference pdf so if an end devices holds 16 keys can the transmitter multicast to 16 clients? At what point does it choke?
    How many gigs was the backbone on the 2960 switch.
    As far as the mod goes:
    Get rid of the #IF_DEFINED for the debug. Just create a simple oneline function like fnDeBug("'xxxxxxx'") so if you choose to compile w/o debug just find & replace fnDebug() w/ //fnDebug(). This would clean up the code and make it readable.
    I would also determine my length_arrays prior to the for loops so that, that function doesn't run on every iteration of the loop.
    Now what's the cost for these xmitters/receivers? I've been basically setting up every job to provide for HDMI over CAT 6 baluns but this w/o the need for a switcher per sei has potential. Of course a good Catalyst switch with a couple of gigs backbone isn't cheap.
    Hi VAV! Thank you for responding to this thread, I was afraid we had not picked the right place to announce our desire to support AMX dealers....
    vining wrote: »
    It is simply a matter of telling the Managed Ethernet switch (via RS232) which VLAN the Receiver is assigned to. Every HDMI Source/Transmitter is put on its own VLAN, and the Receivers "change channels" by switching which VLAN they are a member of. The module in the OP provides this function. The end result is instant seamless switching as demonstrated in the YouTube video at http://www.youtube.com/watch?v=Z0LNaUdWnCA
    The current limit is 200 Receivers, however we can quite easily increase that to 250 if needed. The Transmitter is sending out an IGMP multicast which allows the Receivers to quickly join/leave a broadcast.
    The HDMI over IP solution is totally HDCP compliant. If the HDMI source only supports 16 clients, only 16 Receivers can join the broadcast. If it only support 1 client (i.e. the genius who designed the Motorola Cable STB'), only 1 Receiver can be attached. However, it should be noted that some of the more creative pro installers have observed that using a Component to HDMI converter with those contrary devices will effectively eliminate the key restrictions.
    The 2960 we used for our proof of concept development is the 24TT-L. This switch has 16GB of bandwidth, and has a street price of $600-$700, with dealer costs being somewhat less than that. That switch has 24 100BT LAN ports, and 2 1000BT backbone ports. You can implement VLAN Trunking with these switches, allowing you to distribute the VLANs across multiple cascaded/bridged switches. In the YouTube demonstration video we had 5 HDMI sources (PS3 Blu-Ray at 1080p60, Xbox 360 Video Game at 720p, VuduXL at 1080p24, VuduBX100 at 1080p24, and a Sony HDMI Camcorder at 1080i30) being distributed to 9 screens. The Cisco 2960 24TT-L was showing 4% bandwidth utilization with all 5 sources going at the same time. Keep in mind that because we are using a multi-cast, the bandwidth requirement pretty much stays the same whether we are sending to 2, 20, or 200 screens.
    FYI, we intentionally chose to demonstrate a 5x9 matrix to demonstrate the unmatched flexibility and scalability of the HDMI over IP solution. Unlike the legacy Matrix switchers, our solution can be upgraded in the field quite easily at any time. The theoretical maximum number of inputs is 4096 (IEEE 802.1Q VLAN specification), but the switch we were using "only" supports 256 VLANs.
    Another subtle message in the YouTube video was that we had a mix/match combination of screens with some only supporting 720p, others able to show 1080i but not 1080p, others able to show 1080p60 but not 1080p24, and some that could support 1080p24. We even had 2 DVI computer screens with a native resolution of 1440x900 which demonstrated the value of the integrated scaler in the solution. Basically you can broadcast any source resolution to various screens, allowing each screen to show its preferred native resolution, regardless of the source characteristics.
    I will make sure the author of the module gets pointed to this thread.
    While these devices were launched at CEDIA with an introductory price of $299 for the Transmitter and $250 for the Receivers (with dealer costs being somewhat less), we have since removed these introductory prices from our website at the request of the dealer community. After all, you really can't frame this product with a "retail" price, as it requires systems integration to deliver the magic, and that has a value that only the dealer and customer can agree upon. You can get dealer pricing in the US from www.tecnec.com . If you are in the UK, dealer pricing is available from www.connectivityuk.com. If you are in Europe contact www.comm-tec.de or www.cbk.no for dealer pricing. If you are somewhere else, send me a PM please.
    Ed Qualls
    Just Add Power
    I saw the demo on YouTube and was impressed. The different resolutions on different screens was very clever, as that is an on going problem in distributed HDMI. Does the transmitter/receiver support HDMI 1.3a? Is it upgradeable?
  • This is marvelous! I would definetly try this solution! Common HDMI matrix are always headache for an integrator! You product is what everybody was waiting for!! Do you provide delivery in Russia ?
    a_riot42 wrote: »
    Hi Paul,
    With regards to support for HDMI 1.3a I'd like to first point you to http://www.hdmi.org/learningcenter/faq.aspx#112
    The HDMI over IP devices are compatible with the HDMI 1.3 standard. Is there something within the 1.3a manufacturing and testing issues that you are specifically focused on?
    As for upgradability, there is a flashable EPROM on the HDMI over IP printed circuit board, but we do not anticipate releasing any updates or changes to these "A" series devices. We are working on enhancing the solution, but practically every desired feature requires changes to the hardware, not the firmware. Over time we expect to have several variations available to address the demands of different market segments. We expect this low cost model to remain popular, even after we introduce some more sophisticated (and higher cost) versions.
    Ed Qualls
    Just Add Power
    karageur wrote: »
    I sent you a PM on this.
    Nded,
    FYI that switch lists for $1,295.00 so dealer cost is slightly over the amount you specified. The 2960G 24TTL which has 10/100/1000 x 24 ports is over $3k list.
    Now on the Cisco site, which BTW, I hate cuz I can never find anything I'm looking for, they don't specify which switches have serial ports for IOS command line programming nor do they say anything about telnet connection for IOS CLI. I'm kinda bummed cuz my Catalyst CE520 doesn't have a serial jack & doesn't telnet so I can't even play w/ changing the VLANs. I can obviously use Cisco Config Assistant (CCA) or Cisco Network Assist (CNA) but that defeats the purpose of changing VLANs through AMX code. So do you know if the 2960 supports telnet? Like I said I just can't find anything that even says they have serial ports. I know the Integrated Serives Routers (ISR's) have both & so does my UC520. Unless I call Cisco TAC I can't figure which models I could choose from. I'd prefer telnet over serial but...
    Do the xmitters start broadcasting IGMP availability upon a live video feed and then starts streaming the video when a client joins that group? Just trying to figure out how this operates.
  • The 2960 series support both telnet and serial access to the CLI.
    Nded wrote: »
    Hi Paul,
    No, I thought auto lip sync was introduced with 1.3a but it looks as if it was implemented in 1.3.
    I guess the docs simple state if it supports CLI or not and if it does it's implied that it has both a serial port and telnet access to CLI. That makes perfect sense once you think about it.
  • vining wrote: »
    I don't know if it makes any sense at all, and I honestly have no idea what the docs have to say about the matter. I've just used tons of them in the past, so I figured I'd throw that answer out there....
    vining wrote: »
    Nded,
    I know the 2960-24TT is sold to end users by CDW for $809 ( http://www.cdw.com/shop/products/default.aspx?EDC=850878 ), and when I google for them, I find plenty for sale for about $600. It is "hearsay" from talking with dealers on the phone that has led me to believe that if they are in the network business, they can get it for something less. We don't directly sell/buy the Cisco gear, so I really can't be sure what the street price is for resellers. A more economical switch that has demonstrated itself to work quite well with our HDMI over IP devices is the Dell 3524.
    This gets a little complicated on the actual timing, as any HDMI source that requires HDCP will not stream video until the first Receiver connects to the Transmitter to handle the HDCP handshake requirements. This translates into a few seconds of dark screen time for the first screen to connect to an HDMI source device over the HDMI over IP LAN. The second through 200th device to connect (if allowed by the HDCP keys) join the in progress video stream instantly.
    a_riot42 wrote: »
    Yeah, the good old team at www.hdmi.org have really muddied the waters on this matter. I'm still waiting to see if when anybody is going to stick their neck out and mass produce anything with any of the "features" in HDMI 1.4.
    We are pleased to announce that the Rackmount Transmitter for HDMI over IP will start shipping at the end of this month. You can read about it at http://www.justaddpower.com/vmchk/VBS-Suite-for-High-Definition/90-HDMI-over-IP-Rackmount-Transmitter/flypage.tpl.html
    Here's a picture of the 1RU unit (has 3 HDMI inputs and 3 LAN ports).
    This device is fully compatible with the AMX driver in the OP.
    Has anybody using these J.A.P. devices find it difficult to get any answers from these guys? I been wanting to place an order for weeks and I've sent them a couple of email asking about pricing, distribution, etc. but I can't get any answers. I did get one answer from an email link from their website which just stated what the website stated. I replied to that email asking if there's any distrution outlets or dealer discounts which is a normal question for any dealer to ask and if they don't fine but at least answer the freakin' question.
    If they don't answer a simple sales question which will generate them revenue I can't imagine how forth coming they'll be regarding tech questions and problems. This after I'm basically done with my module to control the Cisco switch via IP and now I'm not sure if it's a smart decision dealing with a company that doesn't respond to queries especially ones that will make them money.
    Hmmm! Anybody got anything positive to say about them?
    I've just sent Vining a PM, and I will do my best to figure out where the breakdown in communications occurred.
    Ed Qualls
    Just Add Power
    vining wrote: »
    Why did you write a module to control a Cisco switch?
    To be able to change the VLANs associated with a port. The switching is accomplished by changing the display port VLAN to match the source device VLAN.
    vining wrote: »
    Can't you do that from the switches web browser? Or are you changing VLANs in real time in response to user requests? I can't imagine a scenario where one would need that functionality.
    From what I have gathered about the Just Add Power solution, the transmitter broadcasts the signal and the receivers decode the broadcast. The way it works, only one transmitter can be present on the network. By using VLANs, you create multiple "separate" networks and you just switch the receiver to be part of the network that contains the transmitter you need.
    Spire_Jeff wrote: »
    But that's cheating isn't it?
    I wouldn't call it cheating. Netflix, Vudu, Apple TV all send video over IP so if you make a switch into what amounts to a matrix hdmi switcher that's completely configurable, 12 in 12 outs, 4 in 20 out, 16 in 8 out and of course there are 48 port switches too with the combinations you can achieve with them. As long as the source device holds enough keys you can send simultaneuously to as many display devices as the source device has keys. You can also just use the componant vid out to hdmi and then there's no worries about keys.
    There presently aren't any 12 x 12 hdmi switchers or 8 x 16 or 24 x 24 or 10 x 30 and you can even casacades switchers to as many as there are possible vlans which I think are 256 with the Cisco 2960 switches.
    Also the switches are under 1k and the tramitters/receivers are he same ans any other type of HDMI over 1/2 CAT5 device. This is just HDMI over IP matrix switching via a manageable switch.
    vining wrote: »
    It should be noted that the Just Add Power HDMI over IP devices use an HDCP Compliant licensed process that overcomes the key limitation. Regardless of how many keys the source device holds, we can shows it on as many screens as needed. For example, a Motorola cable box with only 1 key can still be watched on multiple screens, just as long as each screen has a valid HDCP key. You cannot use the Just Add Power HDMI over IP devices to show protected content on a screen/sink without a valid key.
    Keep in mind that you can link multiple switches together to build a very large matrix. The switches we recommend have STACK ports that automatically distribute the vlans across the network. It is quite easy to connect 8 48 port switches together to realize 384 ports, where any port can be an input or an output to the matrix.
    At a conceptual level, the entry level switches like the Dell 3524 support up to 64 HDMI over IP Transmitters, the intermediate switches like the Cisco 2960 do support up to 256 HDMI over IP Transmitter, the enterprise class switches from Cisco and other companies can support as many as 4096. While the Receivers currently cycle through 200 IP's, it is fairly easy to support installations with several hundred or thousands of screens using a multi-zone implementation of our HDMI over IP solution. This multi-zone scheme is ideal for large venues like airports, casinos, convention centers, and sports arenas.
    It has been noted by some dealers that the Just Add Power HDMI over IP devices have a similar price point as other quality HDMI over CATx baluns. Their observation is that when you buy the Just Add Power "baluns", you get a matrix switch for free. Best of all, it is a right sized matrix that can be upgraded and expanded in the field at any time. This is just not possible with the legacy matrix technology being offered by other companies.
    Nded wrote: »
    These seem to contradict each other... ?
    The Just Add Power HDMI over IP solution has continued to evolve and improve over time. Overcoming the HDCP keys problem is just one of the many things we've accomplished. Over the last 90 days we've added new models like the convertible Rackmount Transmitter and the Power over Ethernet Receiver (the PoE Receiver started shipping this month). We will be introducing more "new and improved" HDMI over IP devices in June at InfoComm in Las Vegas and CEDIA-UK in London. We will follow that up with more interesting things to be unveiled in September at CEDIA in Atlanta. Great feedback and suggestions from the Custom Installer community has given us plenty of ideas where we can continue to enhance and improve the HDMI over IP solution.
