Metreau keypads along with TPs
I am looking for guidance on how to implement Metreau keypads (13 btns) when you have TPs and duet modules...
Each keypad must be able to control various sources (AM/FM/XM tuner, 4 Satellite boxes, DVD changer etc.)
Some room will have 2 keypads (when there is a TV in the room), others will have only one keypad (Audio only) for a total number of keypads = 27.
Do you create a UI module for the keypads and defining only buttons for the keypads?
For devices like DVD player, do you try to keep all controls for it on the same keypad instead of having Play/pause on one Kpd and then Next, Prev etc on the 2nd Kpd?
Thanks for sharing your experience on this.
You could also just create two sets of button arrays and tie them to the same button_event.
primitive example:
define_variable volatile integer TP_Source_Buttons[]= { 101,102,103,104 } volatile integer KP_Source_Buttons[]= { 1,2,3,4 } DEFINE_EVENT button_event[TP_1,TP_Source_Buttons] button_event[KP_1,KP_Source_Buttons] { push: { if(button.input.channel>100) it's a TP { source=get_last(TP_Source_Buttons) } else // <100 - it's a keypad { source=get_last(KP_Source_Buttons) } // you've got the source, now go do something. } }You could also create another dev array with both keypads and TPs and simplify it even more. Just a thought. There's lots of ways to get this gig done.
One more time, thank you for your valuable inputs - definitely bringing different perspective to think about!
//New in 3.10 //Added Keypad Bringtness Commands MODULE_NAME='mdlKeyPadManager_3_10' (DEV vdvKeypadManager, //Module Virtual Device DEV vdvKeypads[], //Array of Virtual Keypads DEV dKeypads[], //Array of Actual Keypads INTEGER nKeypadEnable[], //Aray of Keypad Enable/Disable INTEGER nTableInput[][][], //[5] [16] [2] //Table of Keypad Assignments INTEGER nIncomingLevels[], //Table of Incoming Levels INTEGER nOffBrightness, //Button On Brightness INTEGER nOnBrightness) //Button Off Brightness DEFINE_DEVICE DEFINE_CONSTANT VOLATILE INTEGER nTotKPs=5 VOLATILE INTEGER nTotVKPs=3 DEFINE_TYPE DEFINE_VARIABLE VOLATILE INTEGER nUI VOLATILE INTEGER nBut VOLATILE INTEGER nLoop VOLATILE INTEGER nLoopUI VOLATILE INTEGER nLoopBut VOLATILE INTEGER nTableOutput[255][nTotKPs][nTotVKPs] VOLATILE INTEGER nAssignedPort VOLATILE INTEGER nAssignedChannel DEFINE_LATCHING DEFINE_MUTUALLY_EXCLUSIVE DEFINE_START FOR (nLoopUI=1;nLoopUI<=nTotKPs;nLoopUI++) //Loop of Each Keypad 1-5 { FOR (nLoopBut=1;nLoopBut<=16;nLoopBut++) //Loops of each Button of each keypad 1-16 { nAssignedPort=nTableInput[nLoopUI][nLoopBut][1] nAssignedChannel=nTableInput[nLoopUI][nLoopBut][2] IF (nAssignedPort>0) { nTableOutput[nAssignedChannel][nLoopUI][nAssignedPort]=nLoopBut } } } DEFINE_EVENT DATA_EVENT [vdvKeypads] { ONLINE: SET_VIRTUAL_LEVEL_COUNT(DATA.DEVICE,10) } DATA_EVENT [dKeypads] { ONLINE: SEND_COMMAND DATA.DEVICE,"'@BRT-',ITOA(nOnBrightness),',',ITOA(nOffBrightness)" } BUTTON_EVENT [dKeypads,0] { PUSH: { nUI=GET_LAST (dKeypads) IF (nKeypadEnable[nUI]) { nBut=BUTTON.INPUT.CHANNEL IF (nTableInput[nUI][nBut][1]>0) //There is an virtual keypad button assogned to this real button { DO_PUSH_TIMED (vdvKeypads[nTableInput[nUI][nBut][1]], nTableInput[nUI][nBut][2],DO_PUSH_TIMED_INFINITE) } } } RELEASE: { nUI=GET_LAST (dKeypads) IF (nKeypadEnable[nUI]) { nBut=BUTTON.INPUT.CHANNEL IF (nTableInput[nUI][nBut][1]>0) //There is an virtual keypad button assogned to this real button { DO_RELEASE (vdvKeypads[nTableInput[nUI][nBut][1]], nTableInput[nUI][nBut][2]) } } } } CHANNEL_EVENT [vdvKeypads,0] { ON: { nUI=GET_LAST (vdvKeypads) nBut=CHANNEL.CHANNEL FOR (nLoop=1;nLoop<=nTotKPs;nLoop++) { IF (nTableOutput[nBut][nLoop][nUI]>0) ON [dKeypads[nLoop],nTableOutput[nBut][nLoop][nUI]] } } OFF: { nUI=GET_LAST (vdvKeypads) nBut=CHANNEL.CHANNEL FOR (nLoop=1;nLoop<=nTotKPs;nLoop++) { IF (nTableOutput[nBut][nLoop][nUI]>0) OFF [dKeypads[nLoop],nTableOutput[nBut][nLoop][nUI]] } } } LEVEL_EVENT [vdvKeypads,0] { IF (nIncomingLevels[LEVEL.INPUT.LEVEL]) //There is an assigned level SEND_LEVEL dKeypads[nIncomingLevels[LEVEL.INPUT.LEVEL]],1,LEVEL.VALUE } DEFINE_PROGRAM
