IR Drivers for Sharp PG-C455W Projector
i am looking to control a projector with one-way communication through IR. i've searched through the AMX third party devices in the tech center section and did not find a *.IRL file for the Sharp PG-C455W. i found one for a XGE3000U sharp projector and was hoping that it would work. all i need is to be able to turn projector off, on, and switch inputs from VGA 1 to VGA 2.
They usually have the hex codes that you need. These can be imported into IREdit.
