Bug in v3.50.430 NI-X100 firmware?
in AMX Hardware
Just been debugging a system and noticed some strange behaviour. When I open a telnet connection to the master the internal message queue processing slows to a halt.
It's not to much of a problem if there is only minimal communication happening between devices but if you have any verbose interaction (gating activity, signal levels etc) happening it's enough to freeze up the system.
It only appears to happen when connected via telnet. The system will happilly be processing everything but the second you telnet in you can watch the Interpreter and Java Router buffers (via 'show buffers') start to grow. If you then close the telnet connection and give it a bit of time to clear out the queues it will gradually return to normal.
Anyone else having a similar issue?
The system can be running perfectly, but when you connect response times start to slow right down. I can confirm this by connecting, executing 'show buffers' straight away. It may show around 6 buffered commands by time i've typed and executed and if I continue to execute 'show buffers' I can watch them grow. If I then disconnect and reconnect 30 seconds later I can see that the number of buffered commands has greatly decreased (will return to zero if you give it time) but it will start to grow again whilst connected. Disconnect again and it will work it's way through the buffered messages and return to an operational state.
The question is if the Interpreter is backlogging when there is a Telnet session that is doing nothing. The only way to determine this is to create a Telnet session and execute the show buffers only once to get a "baseline" read of the queues. Then do nothing on the Telnet session for some time before executing the "show buffers" again. If it's a problem with an idle Telnet session sucking CPU, then your count will have increased dramatically. If not, then the count should be about the same as the first execution.
What is the load like with regards to incoming event data? Is the Input LED on solid?
Monitoring device activity via the diagnostics window doesn't seem to affect the buffers.
@shane-a-roo
That's the way I've been testing this. If this system is only under minimal load (basic device control and occasional status updates) you don't really notice it a great amount, the response times slow down but becuase there's not a lot of messgaes passing through the queues it will catch back up within a second or two. Where I really notice it is when I start receiving things like gate status and signal presence feedback from the DSP's. The ClearOne's trigger abour 4 - 6 data events per second on top of other system traffic which quickly start to fill things up.
I wonder, however, if it's really new to this version. I have seen device notifications back up the queue like that when turned on, then clear when turned off again. It's entirely possible this has always happened and the new version simply has more going on, so it's more noticeable.
