Home AMX Technical Discussion
Capturing IR with Metreau 6N
Hi,
Can anyone confirm if it is possible to capture IR commands with Metreau 6N keypad ?
Thank you.
  • You can receive AMX IR codes with them, but no you cannot capture third party IR
  • Thak you for reply, so is there a way of capturing third party IR codes ?
  • PhreaKPhreaK Posts: 966
    AMX manufacture a device called IRIS (http://www.amx.com/products/IRIS.asp) for this exact purpose. Alternatively you can create your own IR files form hex codes that can be found on various universal remote and enthusiast sites. If you do a quick search of this forum there are a few threads that will point you in the right direction.
  • Geart, thanks
