New to programming, please help!
Brooks Whiteford
in AMX Hardware
Hello everyone! Great forum, and thanks for your help in advance.
I have a NI-3100 with an AXB-VOL3 connected over Axlink. I've loaded a program from another NI-3100 onto it, and for some reason the status led on the front of the controller stays solid, it does not flash. The input led appears to be functioning properly as anything I do from NetLinx Studio causes it to flash.
In addition, The AXlink LED on the VOL3 is blinking once a second, but the LED on the back of the controller is not blinking at all.
I assume this means my program is not running, and when I run program info from telnet it tells me nothing is running.
Please help! Thanks!
Thanks so much for the quick reply. I did check that, and it is indeed off. No luck there.
when you say you loaded a program from one master to another, what do you mean? How did you go about doing that? Perhaps there's a flaw in that process.
I also found some sample code in the forum also that demonstrates the capabilities of digital IO ports. So, I made a new workspace, set that code as the master, then loaded it on, and the same result. I thought by doing that i'd be simplifying things, but the program still does not appear to be running. Am I missing a step in the loading \ running code process?
Well, a lot depends upon the first working code.
First things first, however.
Telnet into the master and do a 'clean disk' command. this will erase all program files off the master. That way you can have a clean start. run the command and reboot.
then what I'd do is make a new project and start off with an empty template as the master file. Try loading that and see if it comes alive. If a blank program won't run, there is something wrong with the NI master.
It might be a corrupt flash image or something physically wrong with the unit. IF it does come alive, then there's something wrong with your code.
Give that a whirl and report back.
e
Ran clean disk and it did it's thing. Then I created a new workspace, and a source file via the NetLinx template. I called the file Master.axs. Then, I uploaded Master.tkn and Master.src to the controller. It rebooted, but still a solid status led. Input blinks every once in a while.
Any idea what to try next? Would access to the controller via the internet be helpful? Thanks so much for your help Eric, I owe you big time!
Dipswitch = ON OFF OFF OFF OFF ON ON ON
Doesn't that suggest that the PRD switch is on? I checked the switch and it's definitely off.
I've discovered that the controller definitely thinks that dipswitch 1 is on, and I tried everything I could to get it to "think" it's off. I'm assuming this is my issue. Any idea why dipswitch 1 will not turn off even though it appears to be physically off?
That sounds like the switch may be stuck or needs cleaning. you might try flipping the switch on and off several times to clean it out. Otherwise, it might be genuinely broken. If so, you'll have to call tech support.
There was a small bead of solder connecting the one of the pins for dipswitch one two another solder point on the main board. The bead popped right off, and now the switch functions normally!
All's well that ends well...
