I-weather and ENV-Viewstat
Hi there,
This is my first time to install this device. I am confused how does it work with this modules.
My setup would have a 6 ENV-Viewstat and NI900. I need to see the weather updates on viewstat. AMX had send Authorization Code for I-Weather which I dont have any idea where to install this codes.
Thank you so much for reading and looking forward for your replies.
    You don't have to configure the iWeather module to talk with the HVAC module at all. This is done within the HVAC module for you. All you have to do is make sure you set the ZIPCODE and other information correctly for iWeather according to the documentation that comes with the module.
    As for the thermostat, I believe they detail multiple stat configuration in the documentation. If not, I can try to find some code that details the setup.
