Using wired "IR-in" port on consumer devices?
Anyone have a hint how to connect a wired "IR-in" port found on some consumer gear to AMX equipment? Like for instance on the Oppo HM-31 HDMI switch (it also has RS-232 but there are others too). Thanks!
As Vining said, it shouldn't hurt to try plugging in directly and spitting IR at it with the carrier on and then off. If you do a little snooping with a multimeter it should be obvious if the input floats high and you need to invert the signal (I always drive the base of a transistor through a resistor to achieve this).
I wouldn't do that - just use the gnd and data pins to connect to the IR port - leave the +5v disconnected.
Good point, I was thinking by shortening you meant shortening the ring and sleeve conductors on the jack. By shortening I hope you don't mean shorting. Connecting GND to +5V would be a very, very bad thing. +5V should be left unconnected.
