Now I see U, now I don't...
I am involved with a project that the client wants to have glass walls that will darken. I am wondering if anyone has ever used this technology and interfaced it with AMX?
Just do a google search (or search engine of your choice) for 'Smart Windows' and you'll see a bevy of companies offering products. We've seen windows that opacify to certain levels (darken like sunglasses) but none that go completely opaque (completely dark)
It seems that they were having problems being able to keep the glass blacked out (they were using LCD tech I think) and there were problems with the glass turning clear in the middle of taking a shower or at other inopportune times
That may be why Eric has not found a solution that goes completely dark?
I think the problem has been to find a substance that go from one extreme to the other. It's not hard to find stuff that'll go all black. But it then doesn't clear up enough to be completely see-through. The systems I've seen use the same technology as an LCD display. I wasn't actually involved with installing or integrating them in that they connected to a lutron system with pretty much a contact closure. And then I was hooked up to the Lutron system.
I do know it was silly expensive and the result wan't that spectacular.
I used to work at a prison that used a type of window that was perfectly clear but with a flip of a light switch would turn "frosted" for privacy. Something like this...
http://www.electricglasswall.com/
ERIC
Isoclima's SPD technology was licensed out to another company called smartglass too, here's a demo page: http://www.smartglass.com/demo.asp
Contacting either mfg. they'll probably give you whitepapers or design guides on the product. Sounds like a fun project.
--John
