DEFINE_FUNCTION CHAR[500] URLEncode(CHAR Input[500]) { STACK_VAR INTEGER i STACK_VAR CHAR TEMP[500] STACK_VAR CHAR URLChars[24] URLChars = '$&+,/:;=?@ "<>#%{}|\^~[]`' TEMP = '' i = 1 FOR (i = 1; i <= LENGTH_STRING(Input); i++) { IF (FIND_STRING(URLChars,MID_STRING(Input,i,1),1)) { TEMP = "TEMP,'%',FORMAT('%02X',Input[i])" } ELSE { TEMP = "TEMP,Input[i]" } } RETURN TEMP }
DEFINE_FUNCTION CHAR[AXIS_PRESET_NAME_LEN * 3] fnURL_Encode(CHAR iStr[]) { STACK_VAR INTEGER i ; STACK_VAR INTEGER nEncodeByte; STACK_VAR INTEGER nLenURLStr ; STACK_VAR CHAR cURL_EncodeStr[AXIS_PRESET_NAME_LEN * 3] ;//must be bigger. you might be swapping 1 char for 3! fnAxis_DeBug("'URL Encode In: ',iSTR,'.>-line-<',ITOA(__LINE__),'>'") ; nLenURLStr = length_string(iStr) ; for(i = 1 ; i <= nLenURLStr ; i ++) { if(iStr[i] > 31 && iStr[i] < 48 || iStr[i] > 57 && iStr[i] < 65 || iStr[i] > 90 && iStr[i] < 97 || iStr[i] > 122 && iStr[i] < 127) { nEncodeByte = iStr[i] ; cURL_EncodeStr = "cURL_EncodeStr,GET_BUFFER_STRING(iStr,i-1),'%',ITOHEX(nEncodeByte)" ; GET_BUFFER_CHAR(iStr) ; nLenURLStr = length_string(iStr) ; i = 0 ; } } fnAxis_DeBug("'URL Encode Out: ',cURL_EncodeStr,iStr,'.>-line-<',ITOA(__LINE__),'>'") ; RETURN "cURL_EncodeStr,iStr" ; }
DEFINE_FUNCTION CHAR[500] URLEncode(CHAR Input[500]) { STACK_VAR INTEGER i STACK_VAR CHAR TEMP[500] STACK_VAR CHAR URLChars[24] URLChars = '$&+,/:;=?@ "<>#%{}|\^~[]`' TEMP = '' i = 1 FOR (i = 1; i <= LENGTH_STRING(Input); i++) { IF (FIND_STRING(URLChars,MID_STRING(Input,i,1),1)) { TEMP = "TEMP,'%',FORMAT('%02X',Input[i])" } ELSE { TEMP = "TEMP,Input[i]" } } RETURN TEMP }DEFINE_FUNCTION CHAR[AXIS_PRESET_NAME_LEN * 3] fnURL_Encode(CHAR iStr[]) { STACK_VAR INTEGER i ; STACK_VAR INTEGER nEncodeByte; STACK_VAR INTEGER nLenURLStr ; STACK_VAR CHAR cURL_EncodeStr[AXIS_PRESET_NAME_LEN * 3] ;//must be bigger. you might be swapping 1 char for 3! fnAxis_DeBug("'URL Encode In: ',iSTR,'.>-line-<',ITOA(__LINE__),'>'") ; nLenURLStr = length_string(iStr) ; for(i = 1 ; i <= nLenURLStr ; i ++) { if(iStr[i] > 31 && iStr[i] < 48 || iStr[i] > 57 && iStr[i] < 65 || iStr[i] > 90 && iStr[i] < 97 || iStr[i] > 122 && iStr[i] < 127) { nEncodeByte = iStr[i] ; cURL_EncodeStr = "cURL_EncodeStr,GET_BUFFER_STRING(iStr,i-1),'%',ITOHEX(nEncodeByte)" ; GET_BUFFER_CHAR(iStr) ; nLenURLStr = length_string(iStr) ; i = 0 ; } } fnAxis_DeBug("'URL Encode Out: ',cURL_EncodeStr,iStr,'.>-line-<',ITOA(__LINE__),'>'") ; RETURN "cURL_EncodeStr,iStr" ; }
