Tango Controller - Fixed Output?
Please look at the attached picture.
I am getting audio out on the 8th zone via GREEN "A" but no audio out via GREEN "B". Is there a fixed audio out setting I am missing? Any help would be greatly appreciated.
Rob
    Your 'B' is not a zone output, but rather a source output to cascade to a second tango unit - or line level pass through for the source (not zone) 8 audio to some other device. The audio outputs shown in the 'B' section of your diagram are simply to pass the signal of the corresponding input.
    Do you have something plugged into source input 8? If so, that should be what you hear coming out if your 'B' output 8.
    To further clarify, if you had a 16 zone system, you would plug your sources into the inputs 1-8 of the first tango. Rather than use a y-splitter to feed the second tango unit, your would run rca cables from the OUTPUT -- your 'B' -- to the corresponding source INPUT on the second Tango unit.
    If you are looking to take the zone output of the Tango and convert that to line level to input into a local receiver, you would want the line level converter: http://www.amx.com/products/DAS-LLC.asp
    This is common for a system that has a tango feeding the whole house distributed audio and where one room is a local 5.1 system and you want the house feed as one of the source inputs into your local receiver. You should be able to set the volume output for the particular zone output to a fixed level.
  • abuddyabuddy Posts: 4
    Thanks for the input!
    Any suggestions on how to connect another amp to drive an outside zone with a volume control?
    Rob
    PDF page 22 (document page 14) shows how to wire a tango AMP into the mix:
    http://amx.com//techdocs/DAS.Tango.Controllers.OperationReferenceGuide.pdf
    PDF page 33 (document page 25) shows how to wire to a generic amp. The starts the section on special wiring configurations, and I believe your scenario will be described here.
    Thanks again Chris
