Be Gentle Please
Garret
This is the first bit of AMX code i have written and the fist bit of code of any type I have done in about 12 years. I would appreciate some tips or critique of what I'm doing here. It all seems to work as I expect but needs some polish. I considered including the .AXW file but that was 10 megs and I was unsure how the forum host would feel about that.
Thank you for any advice you may have.
Garret
Garret
PROGRAM_NAME='SHOWROOM_MAIN001' (***********************************************************) (***********************************************************) (* FILE_LAST_MODIFIED_ON: 04/05/2006 AT: 09:00:25 *) (***********************************************************) (* System Type : NetLinx *) (***********************************************************) (* REV HISTORY: *) (***********************************************************) (* $History: $ *) (***********************************************************) (* DEVICE NUMBER DEFINITIONS GO BELOW *) (***********************************************************) DEFINE_DEVICE MASTER = 0:1:0 //HOUSE CONTROLLER, AMX NI-3100 dvARQ1 = 0:2:0 //Set the IP Address or Baud settings in the ARQ Main v6_0_2 file!! dvVANTAGE = 0:3:0 //VANTAGE SYSTEM //--DEVICE DEFFINISIONS dvAVRECEIVER232 = 5001:1:0 //AV RECEIVER FOR FRONT ROOM SURROUND dvAVSWITCH232 = 5001:2:0 //AV MATREX SWITCHER FOR SHOW ROOM dvTVCONFRENCE232 = 5001:6:0 //CONFRENCE ROOM TV dvTVFRONT232 = 5001:7:0 //FRONT ROOM TV dvSATIR = 5001:15:0 //STORE SAT DVR dvBLUERAYIR = 5001:16:0 //SHOWROOM BLUERAY dvGAME = 5001:14:0 dvRELAYS = 5001:8:0 //RELAY SECTION OF CONTROLLER dvIO = 5001:17:0 //I/O SECTION OF CONTROLLER //---TOUCH PANNEL DEFFINISIONS dvTP_CONFRENCE_MAIN = 10001:1:0 dvTP_CONFRENCE_SW = 10001:2:0 dvTP_CONFRENCE_SAT = 10001:11:0 dvTP_CONFRENCE_BLUERAY = 10001:12:0 dvTP_CONFRENCE_GAME = 10001:13:0 dvTP_CONFRENCE_REQUEST = 10001:14:0 dvTP_CONFRENCE_RADIO = 10001:15:0 dvTP_CONFRENCE_LIGHTS = 10001:20:0 dvTP_CONFRENCE_LIGHTS_S = 10001:21:0 //SLIDER FUNCTIONS FOR LIGHTS PAGE dvTP_FRONT_MAIN = 10002:1:0 dvTP_FRONT_SW = 10002:2:0 dvTP_FRONT_SAT = 10002:11:0 dvTP_FRONT_BLUERAY = 10002:12:0 dvTP_FRONT_GAME = 10002:13:0 dvTP_FRONT_REQUEST = 10002:14:0 dvTP_FRONT_RADIO = 10002:15:0 dvTP_FRONT_LIGHTS = 10002:20:0 dvTP_FRONT_LIGHTS_S = 10002:21:0 //VIRTUAL DEVICES vdvARQ1_1 = 34000:1:0; //Virtual device for ARQ 1, Zone 1 vdvARQ1_2 = 34001:1:0; //Virtual device for ARQ 1, Zone 2 vdvARQ1_3 = 34002:1:0; //Virtual device for ARQ 1, Zone 3 vdvARQ1_4 = 34003:1:0; //Virtual device for ARQ 1, Zone 4 (***********************************************************) (* CONSTANT DEFINITIONS GO BELOW *) (***********************************************************) DEFINE_CONSTANT //VANTAGE CONTROLLER CONNECTION INFORMATION CHAR sIPVANTAGE [] = '10.0.0.16' svPORT = 3001 IP_TCP = 1 (*ADD ALL THE VIDs OF THE LOADS IN THE VANTAGE SYSTEM*) NON_VOLATILE CHAR cLOADVID[2000] = {'23 24 25 26 27 28 29 30 31 33 34 35 36 37 38 39'} (*MAKE SURE THE STRING STARTS WITH A SPACE*) SATPower_On = 27 SATPower_Off = 28 BRAYPower = 9 //SYNC CONSTANTS SYNC1 = 1 SYNC2 = 2 SYNC3 = 3 SYNC4 = 4 SYNC5 = 5 SYNC6 = 6 SYNCSAT = 7 SYNCBLUERAY = 8 (***********************************************************) (* DATA TYPE DEFINITIONS GO BELOW *) (***********************************************************) DEFINE_TYPE (***********************************************************) (* VARIABLE DEFINITIONS GO BELOW *) (***********************************************************) DEFINE_VARIABLE //DEVICE ARRAYS DEV arrTPMAIN[] = {dvTP_CONFRENCE_MAIN,dvTP_FRONT_MAIN} DEV arrTPSAT[] = {dvTP_CONFRENCE_SAT,dvTP_FRONT_SAT} DEV arrTPBLUERAY[] = {dvTP_CONFRENCE_BLUERAY,dvTP_FRONT_BLUERAY} DEV arrTPREQUEST[] = {dvTP_CONFRENCE_REQUEST,dvTP_FRONT_REQUEST} DEV arrTPLIGHTS[] = {dvTP_CONFRENCE_LIGHTS,dvTP_FRONT_LIGHTS} DEV arrTPLIGHTS_S[] = {dvTP_CONFRENCE_LIGHTS_S,dvTP_FRONT_LIGHTS_S} DEV arrTPRADIO[] = {dvTP_CONFRENCE_RADIO,dvTP_FRONT_RADIO} DEV arrTV[] = {dvTVCONFRENCE232,dvTVFRONT232} //TP VARIABLES //RECEIVER VARIABLES VOLATILE CHAR cRECEIVERBUFF[100] //SAVES THE RECEIVER FEEDBACK FOR TROUBLESHOOTING NON_VOLATILE CHAR cRECEIVERTUNER[50] //FREQUENCY THE TUNER IS AT NON_VOLATILE CHAR cRECEIVERINPUT[50] //INPUT OF MAIN ZONE NON_VOLATILE CHAR cRECEIVERINPUTZA[50] //INPUT OF ZONE A NON_VOLATILE CHAR cRECEIVERVOLUME[50] //VOLUME OF MAIN ZONE NON_VOLATILE CHAR cRECEIVERVOLUMEZA[50] //VOLUME OF ZONE A NON_VOLATILE INTEGER nRECEIVERPOWERSTATUS //POWER OF MAIN ZONE NON_VOLATILE INTEGER nRECEIVERPOWERSTATUSZA //POWER OF ZONE A NON_VOLATILE INTEGER nRECEIVERMUTE //MUTE STATUS OF MAIN ZONE NON_VOLATILE INTEGER nRECEIVERMUTEZA //MUTE STATUS OF ZONE A NON_VOLATILE DOUBLE dRECEIVERVOLUME //VOLUME OF MAIN ZONE NON_VOLATILE DOUBLE dRECEIVERVOLUMEZA //VOLUME OF ZONE A //SWITCHER VARIABLES VOLATILE CHAR cSWBUFF[50] //MATREX SWITCHER BUFFER NON_VOLATILE INTEGER iCRSWOI //CONFRENCE ROOM SWITCHER OUTPUT NON_VOLATILE INTEGER iFRSWOI //FRONT ROOM SWITCHER OUTPUT //CONFRENCE TV VARIABLES VOLATILE CHAR cCONFRENCETVBUFF[50] //CONFRENCE TV FEEDBACK BUFFER VOLATILE INTEGER nCTVPOWERONDEADTIME //CONFRENCE TV HOLD FOR TV POWER ON //IR VARIABLES VOLATILE INTEGER nBICSAT //SAT FEEDBACK VARIABLE VOLATILE INTEGER nBICBLUERAY //BLUERAY FEEDBACK VARIABLE VOLATILE INTEGER nBICAVSWITCH //COMPONET SWITCHER FEEDBACK VARIABLE //FRONT TV VARIABLES VOLATILE CHAR cFRONTTVBUFF[50] //FRONT TV FEEDBACK BUFFER VOLATILE INTEGER nFTVPOWERONDEADTIME //FRONT TV HOLD FOR TV POWER ON //VANTAGE VARIABLES VOLATILE CHAR cVANTAGEBUFF[1000] //VANTAGE TROUBLESHOOTING VAREABLE VOLATILE CHAR cVANTAGEBUFFPART[100] VOLATILE CHAR cVANTAGELEVEL[50] //USED FOR LEVEL VALUE DATA PARSEING VOLATILE DOUBLE iVANTAGELEVEL //MATH OPPERATION TO PARSE DATA NON_VOLATILE INTEGER nLIGHTLEVELS[40][1] VOLATILE CHAR cTEMP[40] VOLATILE INTEGER iTEMP VOLATILE CHAR cTPBUFF[100] //TP FEEDBACK (***********************************************************) (* LATCHING DEFINITIONS GO BELOW *) (***********************************************************) DEFINE_LATCHING (***********************************************************) (* MUTUALLY EXCLUSIVE DEFINITIONS GO BELOW *) (***********************************************************) DEFINE_MUTUALLY_EXCLUSIVE (***********************************************************) (* SUBROUTINE/FUNCTION DEFINITIONS GO BELOW *) (***********************************************************) #include 'ARQ Defines v6_0_2.axi'; #include 'ARQ Main v6_0_2.axi'; #include 'ARQ TP Interface v6_0_2.axi'; #INCLUDE 'DEFINE_CALL.AXI' (***********************************************************) (* STARTUP CODE GOES BELOW *) (***********************************************************) DEFINE_START IP_CLIENT_OPEN (dvVANTAGE.PORT,sIPVANTAGE,svPORT,IP_TCP) //OPENS THE PORT TO ALLOW COMMUNICATION TO VANTAGE CREATE_BUFFER dvAVRECEIVER232, cRECEIVERBUFF CREATE_BUFFER dvTP_CONFRENCE_MAIN, cTPBUFF CREATE_BUFFER dvVANTAGE, cVANTAGEBUFF DEFINE_START //THE SECOND PART OF DEFINE_START IS IGNORED WITHOUT THIS SECOND DEFINE #INCLUDE 'ARQ INCLUDE.AXI'; (***********************************************************) (* THE EVENTS GO BELOW *) (***********************************************************) DEFINE_EVENT //--------------------------MACRO AND SOURCE COMMANDS BUTTON_EVENT [dvTP_FRONT_MAIN,0] //MACRO AND VOLUME COMMANDS FOR FRONT ROOM { PUSH: { SWITCH (BUTTON.INPUT.CHANNEL) { CASE 11: //DVR-------------------------------------------------------- CALL'FRONT_TV_ON' CALL'FRONT_TV_INPUT1' CALL'FRNT_RECEIVER_DSS' CALL'FRNT_SW_01' IF (![dvIO,SYNCSAT]) PULSE [dvSATIR,SATPower_On] CASE 12: //DVD-------------------------------------------------------- CALL'FRONT_TV_ON' CALL'FRONT_TV_INPUT2' CALL'FRNT_RECEIVER_DVD' CALL'FRNT_SW_02' IF (![dvIO,SYNCBLUERAY]) PULSE [dvBLUERAYIR,BRAYPower] CASE 13: //PS3-------------------------------------------------------- CALL 'FRONT_TV_ON' CASE 14: //REQUEST---------------------------------------------------- CALL'FRNT_SW_04' CALL'FRONT_TV_OFF' CASE 15: //RADIO------------------------------------------------------ CALL'FRNT_RECEIVER_RADIO' CASE 24: //VOLUME UP-------------------------------------------------- CALL 'FRNT_RECEIVER_VOLUME+' CASE 25: //VOLUME DOWN------------------------------------------------ CALL 'FRNT_RECEIVER_VOLUME-' CASE 26: //MUTE------------------------------------------------------- CALL 'FRNT_RECEIVER_MUTE' CASE 28: //OFF-------------------------------------------------------- CALL'FRONT_TV_OFF' CALL'FRNT_RECEIVER_OFF' IF (nRECEIVERPOWERSTATUSZA=0) { CALL'SW_OFF' IF ([dvIO,SYNCSAT]) PULSE [dvSATIR,SATPower_Off] IF ([dvIO,SYNCBLUERAY]) PULSE [dvBLUERAYIR,BRAYPower] } } } HOLD[4,REPEAT]: { SWITCH (BUTTON.INPUT.CHANNEL) { CASE 24: CALL 'FRNT_RECEIVER_VOLUME+' CASE 25: CALL 'FRNT_RECEIVER_VOLUME-' } } } BUTTON_EVENT [dvTP_CONFRENCE_MAIN,0] //MACRO AND VOLUME COMMANDS FOR CONFRENCE ROOM { PUSH: { SWITCH (BUTTON.INPUT.CHANNEL) { CASE 11: //DVR-------------------------------------------------------- CALL'CONFRENCE_TV_ON' CALL'CONFRENCE_TV_INPUT1' CALL'CR_RECEIVER_VCR' CALL'CR_SW_01' IF (![dvIO,SYNCSAT]) PULSE [dvSATIR,SATPower_On] CASE 12: //DVD-------------------------------------------------------- CALL'CONFRENCE_TV_ON' CALL'CONFRENCE_TV_INPUT2' CALL'CR_RECEIVER_VCR' CALL'CR_SW_02' IF (![dvIO,SYNCBLUERAY]) PULSE [dvBLUERAYIR,BRAYPower] CASE 13: //PS3-------------------------------------------------------- CALL'CONFRENCE_TV_ON' CALL'CONFRENCE_TV_INPUT7' CALL'CR_RECEIVER_VCR' CALL'CR_SW_03' CALL 'CONFRENCE_TV_ON' CASE 14: //REQUEST---------------------------------------------------- CALL'CR_RECEIVER_VCR' CALL'CR_SW_04' CALL'CONFRENCE_TV_OFF' CASE 15: //RADIO------------------------------------------------------ CALL'CR_RECEIVER_RADIO' CASE 24: //VOLUME UP-------------------------------------------------- CALL 'CR_RECEIVER_VOLUME+' CASE 25: //VOLUME DOWN------------------------------------------------ CALL 'CR_RECEIVER_VOLUME-' CASE 26: //MUTE------------------------------------------------------- CALL 'CR_RECEIVER_MUTE' CASE 28: //OFF-------------------------------------------------------- CALL'CONFRENCE_TV_OFF' CALL'CR_RECEIVER_OFF' IF (nRECEIVERPOWERSTATUS=0) { CALL 'SW_OFF' IF ([dvIO,SYNCSAT]) PULSE [dvSATIR,SATPower_Off] IF ([dvIO,SYNCBLUERAY]) PULSE [dvBLUERAYIR,BRAYPower] } } } HOLD[1,REPEAT]: { SWITCH (BUTTON.INPUT.CHANNEL) { CASE 24: CALL 'CR_RECEIVER_VOLUME+' CASE 25: CALL 'CR_RECEIVER_VOLUME-' } } } DEFINE_EVENT //--------------------------DATA EVENTS ONLINE AND STRING STUFF AND SUCH DATA_EVENT [0:dvVANTAGE.PORT:0] //VANTAGE IP FUNCTIONS { ONLINE: { SEND_STRING dvVANTAGE, "'ADDSTATUS ',cLOADVID,$0D,$0A" //ADDS ALL THE LOADS WHOS STATUS ARE TO BE MONITORED SEND_STRING dvVANTAGE, "'LISTSTATUS',$0D,$0A" WAIT 10 { SEND_STRING dvVANTAGE, "'TASK 919 RELEASE',$0D,$0A" //RUNS A TASK THAT UPDATES ALL THE LIGHT LEVELS SEND_STRING dvVANTAGE, "'TASK 919 RELEASE',$0D,$0A" //TURNS THAT TASK OFF IDEALY THIS HAPPENS SO QUICKLY NO ONE SEES } } } DATA_EVENT [dvAVRECEIVER232] //RS232 FUNCTIONS FOR THE RECEIVER { ONLINE: //WHEN THE DEVISE COMES ONLINE { SEND_COMMAND dvAVRECEIVER232,"'SET BAUD 9600,N,8,1 485 DISABLE'" WAIT 10 SEND_STRING dvAVRECEIVER232, "'@AST:1',$0D" //SETS THE FEEDBACK VOLUME FROM THE RECEIVER TO MOST PERTANANT COMMANDS WAIT 10 SEND_STRING dvAVRECEIVER232, "'@MSP:?',$0D" //CHECK IF ZA IS ON IT DOSENT HAPPEN AUTOMATICLY WAIT 10 { IF (nRECEIVERPOWERSTATUS=1) //CHECKS THE TUNER STATUS IF THE RECEIVER IS ON DURING A REBOOT { CALL 'FRNT_RECEIVER_FREQ?' //CHECK WHAT FREQUENCY THE TUNER IS } ELSE IF (nRECEIVERPOWERSTATUS=0 AND nRECEIVERPOWERSTATUSZA=1) { CALL 'CR_RECEIVER_FREQ?' //IF ONLY ZONE A IS ON CHECK USING THIS METHOD } } } STRING: { // cRECEIVERBUFF = DATA.TEXT //THROWS THE RETURN STRINGS INTO VARIABLE TO KEEP A DEBUG EYE ON IT { IF (FIND_STRING (DATA.TEXT,"'@PWR:1'",1)) //POWER OFF RETURN STRING MAIN nRECEIVERPOWERSTATUS=0 ELSE IF (FIND_STRING (DATA.TEXT,"'@PWR:2'",1)) //POWER ON RETURN STRING MAIN nRECEIVERPOWERSTATUS=1 ELSE IF (FIND_STRING (DATA.TEXT,"'@MSP:1'",1)) //POWER OFF RETURN STRING ZA nRECEIVERPOWERSTATUSZA=0 ELSE IF (FIND_STRING (DATA.TEXT,"'@MSP:2'",1)) //POWER ON RETURN STRING ZA nRECEIVERPOWERSTATUSZA=1 ELSE IF (FIND_STRING (DATA.TEXT,"'@AMT:1'",1)) //MUTE OFF RETURN STRING MAIN nRECEIVERMUTE=0 ELSE IF (FIND_STRING (DATA.TEXT,"'@AMT:2'",1)) //MUTE ON RETURN STRING MAIN nRECEIVERMUTE=1 ELSE IF (FIND_STRING (DATA.TEXT,"'@MSM:1'",1)) //MUTE OFF RETURN STRING ZA nRECEIVERMUTEZA=0 ELSE IF (FIND_STRING (DATA.TEXT,"'@MSM:2'",1)) //MUTE ON RETURN STRING ZA nRECEIVERMUTEZA=1 ELSE IF (FIND_STRING (DATA.TEXT,"'VOL'",1)) //VOLUME RETURN STRINGS DATA HANDLING MAIN { cRECEIVERVOLUME=DATA.TEXT //VOLUME DATA PARSING IF (FIND_STRING (cRECEIVERVOLUME,"'ZZ'",1)) //IF THE VOLUME IS ALL THE WAY DOWN THE RECEIVER RETURNS ZZ INSTEAD OF A NUMBER { dRECEIVERVOLUME=0 } ELSE { (*SETS THE VOLUME FEEDBACK TO A VALUE OF 0 TO 255*) dRECEIVERVOLUME= ((ATOI(cRECEIVERVOLUME)+71)*255/89) } SEND_COMMAND dvTP_FRONT_MAIN, "'^TXT-52,1&2,','VOLUME',MID_STRING(cRECEIVERVOLUME,6,4)" //VOLUME FEEDBACK MAIN SEND_LEVEL dvTP_FRONT_MAIN,52,dRECEIVERVOLUME //SENDS THE LEVEL INFO TO BUTTON 52 OF MAPPED TP } ELSE IF (FIND_STRING (DATA.TEXT,"'MSV'",1)) //VOLUME RETURN STRINGS DATA HANDLING ZA { cRECEIVERVOLUMEZA=DATA.TEXT //VOLUME DATA PARSING ZA (***SETS THE VOLUME FEEDBACK TO A VALUE OF 0 TO 255***) dRECEIVERVOLUMEZA= ((ATOI(cRECEIVERVOLUMEZA)+90)*255/90) SEND_COMMAND dvTP_CONFRENCE_MAIN, "'^TXT-52,1&2,','VOLUME',MID_STRING(cRECEIVERVOLUMEZA,6,4)" //VOLUME FEEDBACK ZA SEND_LEVEL dvTP_CONFRENCE_MAIN,52,dRECEIVERVOLUMEZA //SENDS THE LEVEL INFO TO BUTTON 52 OF MAPPED TP } ELSE IF (FIND_STRING(DATA.TEXT,"'@SRC:'",1)) //INPUT FUNCTIONS { IF (FIND_STRING (DATA.TEXT,"'@SRC:11'",1)) cRECEIVERINPUT='TV' ELSE IF (FIND_STRING (DATA.TEXT,"'@SRC:22'",1)) cRECEIVERINPUT='DVD' ELSE IF (FIND_STRING (DATA.TEXT,"'@SRC:33'",1)) cRECEIVERINPUT='VCR1' ELSE IF (FIND_STRING (DATA.TEXT,"'@SRC:55'",1)) cRECEIVERINPUT='DSS' ELSE IF (FIND_STRING (DATA.TEXT,"'@SRC:99'",1)) cRECEIVERINPUT='AUX1' ELSE IF (FIND_STRING (DATA.TEXT,"'@SRC:AA'",1)) cRECEIVERINPUT='AUX2' ELSE IF (FIND_STRING (DATA.TEXT,"'@SRC:CC'",1)) cRECEIVERINPUT='CD' ELSE IF (FIND_STRING (DATA.TEXT,"'@SRC:EE'",1)) cRECEIVERINPUT='TAPE' ELSE IF (FIND_STRING (DATA.TEXT,"'F'",7)) cRECEIVERINPUT='TUNER' ELSE IF (FIND_STRING (DATA.TEXT,"'G'",7)) cRECEIVERINPUT='FM' ELSE IF (FIND_STRING (DATA.TEXT,"'H'",7)) cRECEIVERINPUT='AM' ELSE IF (FIND_STRING (DATA.TEXT,"'J'",7)) cRECEIVERINPUT='XM' } ELSE IF (FIND_STRING(DATA.TEXT,"'@MSC:'",1)) //INPUT FUNCTIONS ZA { IF (FIND_STRING (DATA.TEXT,"'11'",1)) cRECEIVERINPUTZA='TV' ELSE IF (FIND_STRING (DATA.TEXT,"'22'",1)) cRECEIVERINPUTZA='DVD' ELSE IF (FIND_STRING (DATA.TEXT,"'33'",1)) cRECEIVERINPUTZA='VCR1' ELSE IF (FIND_STRING (DATA.TEXT,"'55'",1)) cRECEIVERINPUTZA='DSS' ELSE IF (FIND_STRING (DATA.TEXT,"'@99'",1)) cRECEIVERINPUTZA='AUX1' ELSE IF (FIND_STRING (DATA.TEXT,"'AA'",1)) cRECEIVERINPUTZA='AUX2' ELSE IF (FIND_STRING (DATA.TEXT,"'CC'",1)) cRECEIVERINPUTZA='CD' ELSE IF (FIND_STRING (DATA.TEXT,"'EE'",1)) cRECEIVERINPUTZA='TAPE' ELSE IF (FIND_STRING (DATA.TEXT,"'F'",7)) cRECEIVERINPUTZA='TUNER' ELSE IF (FIND_STRING (DATA.TEXT,"'G'",7)) cRECEIVERINPUTZA='FM' ELSE IF (FIND_STRING (DATA.TEXT,"'H'",7)) cRECEIVERINPUTZA='AM' ELSE IF (FIND_STRING (DATA.TEXT,"'J'",7)) cRECEIVERINPUTZA='XM' } (* TUNER FUNCTIONS GO BELOW *) ELSE IF (FIND_STRING(DATA.TEXT,"'@MTF:'",1) OR FIND_STRING(DATA.TEXT,"'@TFQ:'",1)) { cRECEIVERTUNER=(RIGHT_STRING (DATA.TEXT,6)) (*TUNER PARSED DISPLAY COMMANDS BELOW*) IF (ATOI(cRECEIVERTUNER)< 2000) { IF (ATOI(cRECEIVERTUNER)< 512) SEND_COMMAND arrTPRADIO, "'^TXT-50,1&2,','XM',$20,RIGHT_STRING (cRECEIVERTUNER,4),'CH'" ELSE { IF (LEFT_STRING(cRECEIVERTUNER,1)='0') SEND_COMMAND arrTPRADIO, "'^TXT-50,1&2,','AM',$20,RIGHT_STRING (cRECEIVERTUNER,4),'kHz'" ELSE SEND_COMMAND arrTPRADIO, "'^TXT-50,1&2,','AM',$20,RIGHT_STRING (cRECEIVERTUNER,5),'kHz'" } } ELSE { IF (LEFT_STRING(cRECEIVERTUNER,1)='0') SEND_COMMAND arrTPRADIO, "'^TXT-50,1&2,','FM',$20,MID_STRING (cRECEIVERTUNER,2,2),'.',RIGHT_STRING (cRECEIVERTUNER,3),'MHz'" ELSE SEND_COMMAND arrTPRADIO, "'^TXT-50,1&2,','FM',$20,MID_STRING (cRECEIVERTUNER,1,3),'.',RIGHT_STRING (cRECEIVERTUNER,3),'MHz'" } } } } } DATA_EVENT [dvAVSWITCH232] //RS232 FUNCTIONS FOR THE SWITCHER { ONLINE: //WHEN THE DEVISE COMES ONLINE { SEND_COMMAND dvAVSWITCH232,"'SET BAUD 19200,N,8,1 485 DISABLE'" SEND_STRING dvAVSWITCH232, "'p1',$0D" WAIT 10 SEND_STRING dvAVSWITCH232, "'e1',$0D" } STRING: { cSWBUFF=DATA.TEXT } } DATA_EVENT [dvTVFRONT232] //RS232 FUNCTIONS FOR THE FRONT TV { ONLINE: //WHEN THE DEVISE COMES ONLINE { SEND_COMMAND dvTVFRONT232,"'SET BAUD 9600,N,8,1 485 DISABLE'" SEND_STRING dvTVFRONT232, "'RSPW1',$20,$20,$20,$0D" } STRING: { cFRONTTVBUFF=DATA.TEXT } } DATA_EVENT [dvTVCONFRENCE232] //RS232 FUNCTIONS FOR THE CONFRINCE TV { ONLINE: //WHEN THE DEVISE COMES ONLINE { SEND_COMMAND dvTVCONFRENCE232,"'SET BAUD 9600,N,8,1 485 DISABLE'" SEND_STRING dvTVCONFRENCE232, "'RSPW1',$20,$20,$20,$0D" } STRING: { cCONFRENCETVBUFF=DATA.TEXT } } DATA_EVENT [dvSATIR] //IR FUNCTIONS FOR THE SAT RECEIVER { ONLINE: //WHEN THE IR PORT COMES ONLINE { SEND_COMMAND dvSATIR,"'SET IO LINK 1'" //LINKS THE IR DEVICE TO A I/O CHANNEL SEND_COMMAND dvSATIR,"'SET MODE IR'" //SET IT TO IR SEND_COMMAND dvSATIR,"'CARON'" //TURNS THE CARRIOR ON FOR EMMITOR USE SEND_COMMAND dvSATIR,"'XCHM-2'" //SETS XCHM MODE TO 0 } } DATA_EVENT [dvBLUERAYIR] //IR FUNCTIONS FOR THE BLUERAY { ONLINE: //WHEN THE IR PORT COMES ONLINE { SEND_COMMAND dvBLUERAYIR,"'SET IO LINK 1'" //LINKS THE IR DEVICE TO A I/O CHANNEL SEND_COMMAND dvBLUERAYIR,"'SET MODE IR'" //SET IT TO IR SEND_COMMAND dvBLUERAYIR,"'CARON'" //TURNS THE CARRIOR ON FOR EMMITOR USE SEND_COMMAND dvBLUERAYIR,"'XCHM-2'" //SETS XCHM MODE TO 0 } } DATA_EVENT [dvTP_CONFRENCE_MAIN] //TP ONLINE SEND PAGE FEEDBACK TO CONTROLLER { ONLINE: { SEND_COMMAND dvTP_CONFRENCE_MAIN, "'TPAGEON'" } STRING: { IF (FIND_STRING (cTPBUFF,'PPF-LIGHTS',1)) { CLEAR_BUFFER cTPBUFF } } } DEFINE_EVENT //--------------------------DEVICE SPECIFIC COMMANDS CHANNEL UP AND SUCH LEVEL_EVENT [arrTPLIGHTS_S,0] //VANTAGE SYSTEM LEVEL EVENTS REMEMBER THE DOUBLE SLIDERS TO PREVENT INFINATE LOOPS { STACK_VAR FLOAT LIGHTTEMP LIGHTTEMP = (LEVEL.VALUE/2.55) SEND_STRING dvVANTAGE, "'LOAD ',ITOA(LEVEL.INPUT.LEVEL),' ',ITOA(LIGHTTEMP),$0D,$0A" } BUTTON_EVENT [arrTPSAT,0] //IR BUTTON EVENTS FOR THE SAT RECEIVER { PUSH: { STACK_VAR INTEGER BIC BIC = BUTTON.INPUT.CHANNEL nBICSAT = BIC SET_PULSE_TIME (2) PULSE[dvSATIR,BIC] } HOLD[3,REPEAT]: { STACK_VAR INTEGER BIC BIC = BUTTON.INPUT.CHANNEL nBICSAT = BIC SET_PULSE_TIME (1) PULSE[dvSATIR,BIC] } } BUTTON_EVENT [arrTPBLUERAY,0] //IR BUTTON EVENTS FOR THE BLUERAY { PUSH: { STACK_VAR INTEGER BIC BIC = BUTTON.INPUT.CHANNEL nBICBLUERAY = BIC SET_PULSE_TIME (2) PULSE[dvBLUERAYIR,BIC] } HOLD[3,REPEAT]: { STACK_VAR INTEGER BIC BIC = BUTTON.INPUT.CHANNEL nBICBLUERAY = BIC SET_PULSE_TIME (1) PULSE[dvBLUERAYIR,BIC] } } BUTTON_EVENT [arrTPRADIO,0] //RS232 FUNCTIONS FOR THE RADIO { PUSH: { SWITCH (BUTTON.INPUT.CHANNEL) { CASE 164: IF (nRECEIVERPOWERSTATUS=1) CALL 'FRNT_RECEIVER_FREQ+' ELSE CALL 'CR_RECEIVER_FREQ+' CASE 165: IF (nRECEIVERPOWERSTATUS=1) CALL 'FRNT_RECEIVER_FREQ-' ELSE CALL 'CR_RECEIVER_FREQ-' CASE 168: IF (nRECEIVERPOWERSTATUS=1) CALL 'FRNT_RECEIVER_PRESET+' ELSE CALL 'CR_RECEIVER_PRESET+' CASE 169: IF (nRECEIVERPOWERSTATUS=1) CALL 'FRNT_RECEIVER_PRESET-' ELSE CALL 'CR_RECEIVER_PRESET-' CASE 171: IF (nRECEIVERPOWERSTATUS=1) CALL 'FRNT_RECEIVER_FM' ELSE CALL 'CR_RECEIVER_FM' CASE 172: IF (nRECEIVERPOWERSTATUS=1) CALL 'FRNT_RECEIVER_AM' ELSE CALL 'CR_RECEIVER_AM' CASE 173: IF (nRECEIVERPOWERSTATUS=1) CALL 'FRNT_RECEIVER_XM' ELSE CALL 'CR_RECEIVER_XM' } } HOLD[3,REPEAT]: { SWITCH (BUTTON.INPUT.CHANNEL) { CASE 164: IF (nRECEIVERPOWERSTATUS=1) CALL 'FRNT_RECEIVER_FREQ+' ELSE CALL 'CR_RECEIVER_FREQ+' CASE 165: IF (nRECEIVERPOWERSTATUS=1) CALL 'FRNT_RECEIVER_FREQ-' ELSE CALL 'CR_RECEIVER_FREQ-' CASE 168: IF (nRECEIVERPOWERSTATUS=1) CALL 'FRNT_RECEIVER_PRESET+' ELSE CALL 'CR_RECEIVER_PRESET+' CASE 169: IF (nRECEIVERPOWERSTATUS=1) CALL 'FRNT_RECEIVER_PRESET-' ELSE CALL 'CR_RECEIVER_PRESET-' } } } (***********************************************************) (* THE ACTUAL PROGRAM GOES BELOW *) (***********************************************************) DEFINE_PROGRAM [dvTP_CONFRENCE_MAIN,11] = (nRECEIVERPOWERSTATUSZA=1 AND cRECEIVERINPUTZA = 'VCR1' AND iCRSWOI=1 AND [dvIO,SYNCSAT]) [dvTP_CONFRENCE_MAIN,12] = (nRECEIVERPOWERSTATUSZA=1 AND cRECEIVERINPUTZA = 'VCR1' AND iCRSWOI=2) [dvTP_CONFRENCE_MAIN,14] = (nRECEIVERPOWERSTATUSZA=1 AND cRECEIVERINPUTZA = 'VCR1' AND iCRSWOI=4) [dvTP_CONFRENCE_MAIN,28] = (nRECEIVERPOWERSTATUSZA=0) [dvTP_CONFRENCE_MAIN,20] = (FIND_STRING (cTPBUFF,'PPN-LIGHTS',1)) //IR PULSE STATUS WHILE IR IS PULSEING THE STATUS IS ON [arrTPBLUERAY,nBICBLUERAY] = [dvBLUERAYIR,nBICBLUERAY] [arrTPSAT,nBICSAT] = [dvSATIR,nBICSAT] WHILE (FIND_STRING(cVANTAGEBUFF,"$0D,$0A",1)) //WHILE THERE IS A CR AND LF IN THE BUFFER { cVANTAGEBUFFPART = REMOVE_STRING (cVANTAGEBUFF,"$0D,$0A",1) //PULL THE STRING PRECEDEING A CR AND LF OUT OF BUFFER IF (FIND_STRING(cVANTAGEBUFFPART,"'S:STATUS'",1)) //IF STATUS IS IN THE STRING RUN THE FOLLOWING { STACK_VAR INTEGER iVID //CREATE VARIABLE iVID = ATOI (LEFT_STRING (cVANTAGEBUFFPART,14)) //WICH VID CHANGES STATE? cVANTAGELEVEL = RIGHT_STRING (cVANTAGEBUFFPART,8) //PULLSE THE LEVEL OUT OF THE STRING nLIGHTLEVELS[iVID][1] = ATOI (LEFT_STRING (cVANTAGELEVEL,3)) //SAVE LEVELS TO A VID NUMBERED ROW OF THE nLIGHTLEVELS VARIABLE SEND_LEVEL arrTPLIGHTS,iVID,(nLIGHTLEVELS[iVID][1]*2.55) //SENDS THE LEVEL SAVED TO THE TP ARRAY } } (***********************************************************) (* END OF PROGRAM *) (* DO NOT PUT ANY CODE BELOW THIS COMMENT *) (***********************************************************)
I pretty much stopped when you said "it's working"
Just a quick thing, in the data event for the av receiver you've got several wait 10 commands in there. Those don't stack the way you have them written so you run the risk of flooding the device. Also, if you can implement a send queue, that's a good function to have in your library. There are several posts on command queue's.
Again, congratulations on the "it's working" part.
--John
I might add that although not necessary, those stacked waits might be a good place to try creating a timeline. If nothing else it'll give you an easy example of how to do it.
My threshold of pain on using timelines is fairly low. I'll stack waits a lot sooner than make a timeline myself. But I use timelines all the time for lots of things even though there can be a lot of mental overhead with them because they offer a lot of on-the-fly flexibility.
Another thing might be to go ahead and get rid of the button_event[dvtp,0] idea and go with a button array instead. The only reason is the button_event ... ,0] is going to fire on every button event even and the switch/case is going to run every time even though it's going to fire only every so often. No sense cpu-tick-wise to process stuff if you don't need to.
and example of one of your events might be
the nice thing about doing it this way is that it allows you to change the button numbers later if you want to without having to dig through a lot of code. You just change it above in the variable declaration and it all still works below.
But, there's nothing wrong with your method either.
Again thank you for taking the time to help.
I have to agree with that. Closely followed by, "but it worked when I tested it ...".
With all of the advances in 12 year, I'm amazed at how well you grasp the NetLinx Programming.
One comment: Parsing from data.text in a string event can be problematic. The device you're controlling can possibly send 2 or more responses before parsing data.text. I would buffer it and parse the buffer while it has length or the end delimiter of the string coming from the device. In this way you won't miss any feedback from the device.
I didn't know how to setup a buffer until i got to the vantage system which sent back commands too fast, forcing me to find a better way. Do you recommend always using a buffer instead of data.text for feedback parsing? I can see how in larger programs the processor could be dealing with many more IRQ's causing data.text to be lost frequently. Being prepared for those situations even if its not necessary at the moment is probably wise. Alright I have convinced myself. That leads to the next question do you typically handle the parsing of that buffer in mainline similar to what I did?
Thank you for your knowledge,
I'm always impressed by the forums here. This forum is a large amount of the reason I know anything about AMX, I would also like to thank not just the responders to my post but the responders to every post.
I highly recommend you use a buffer. The data.text only shows you the data that causes that event. Sometimes a serial command can end up split across multiple data events. To correctly parse command, you have to look at the data from multiple separate events combined into a single buffer. So, you can create a buffer to hold the data from multiple events, or let create_buffer do this for you.
When dealing with an independent device, yes. You can never be sure how it may be talking to your system, and whether the master will properly interprets pauses (or lack thereof) as a distinct break in the comms, triggering the STRING event. For virtual device communications, a buffer is not necessary, since that is all internal to the master itself.
Thank you,
Saving to variable, yes ... if's, not so much. For parsing, I'm partial to SELECT...ACTIVE or SWITCH...CASE, as appropriate. They are far more scalable, and result in something much easier to follow than 10 levels of nested if's.
if (find_string(incomingResult,'MUTE 1',1))
[dvVortex,1] = find_string(incomingResult,'MUTE 1 1',1)
Now dvVortex has a status for the mute that can be seen to the local program and any master connect to this master. This is also great for using with RMS.
