Home AMX Technical Discussion
Command to change the Touch Style of a button
Hello!
Is there a netlinx command to set the "touch style" of a button??
I need to change dinamically the touch style from "active touch" to "pass through", but i couldn?t find the command, if there is any.
Thanks for your help!!
Salutes!
    I don't believe there is. There is an enable/disable (^ENA) and a show/hide (^SHO). However, if it does exist, look in PI under BMF; there is a ton of stuff in there relating to button manipulation (I was told at an AMX training many years ago that BMF stood for Big-Mother... well, you can surely get the rest on your own :) ).
    DHawthorne wrote: »
    This is perfect!
  • MorgoZMorgoZ Posts: 116
    Ok,
    finally i set the "enable" property of the mouse to false, so it turns "pass through" like :)
    thanks for your help!
