VNC Viewer quit working after panel firmware upgrade
chuckd
Hey guys,
I've been using VNC Viewer just fine for a long time, but yesterday I upgraded my 700VI panels to the new 2.86.24 version and the VNC Viewer will no longer work. If I use the web control through the master, it takes a LONG time to pop up (almost a minute). My 5200i panels on the same system still work just fine as always.
Anyone know of what in the new 700VI firmware would do this?
Chuck
Chuck
Just curious - did you upgrade them remotely or while you were on site?
I'm using the free VNC Viewer, and it doesn't have a configuration for timeout (that I can remember, anyway).
I guess I'm trying to see if this is unique to my installation, or a general problem with the 700Vi's new firmware.
Very odd.
Chuck
When you say the password no longer works, can you elaborate? Do you mean you had a password in there before, and now it uses the default password, or no password at all. Are you able to assign a new password?
chuckd & alexsquared:
1) What version did you upgrade from?
2) Did you happen to cycle through the new "Security" button in the Protected Setup pages? Did you have to go back into the G4 Web Control pages on the panel and re-enable Web control button?
Do not recall what version is was previously on. I just went, disabled G4, re-enabled, and rebooted the unit, and all seems to work now. Additionally, however, it seems as though the firmware upgrade changed the IP setting from Static to DHCP.
Yesterday I connected using TPD4 and downloaded a different panel file to it. Now it is working fine.
3) Did you have to go back into the G4 Web Control pages on the panel and re-enable Web control button?
Chris
1. The previous version was 2.85.14
2. Naturally - I played with everything
3. Yes.
Last night it worked fairly well. I would sometimes get a message that said the connection was reset by peer, but then when I retried it would work. Nothing has changed and the panel is still online, but today I get an error connecting with RealVNC (10061).
I went into the setup page to see that it was online, then went into panel info to look at the current version, then back out. Now I can connect again with an occasional reset by peer message.
So it's possible if you upgraded, then played with the security button (eventually going back to standard mode) - you would have to go back and manually turn on web control and clear out the default 1988 webcontrol password.
That sounds like what happened. Now the only change I've noticed is that it generally takes 3 tries to get connected. First I get the connection reset, then I get connection refused, then I get in.
Yes, in hindsight this is a real problem for us. We should have popped up a warning dialog that specifically notes what is changing and forces an acknowledgment from the user. We tested the heck out of this but never stopped to consider what if someone accidentally presses the button or just presses it to see what would happen. It does look like any other toggle button on the panel but obviously it isn't. We will look at what we can do to make this more accident-proof.
This is a much shorter and more efficient process which is very much appreciated and far less people have to suffer this way.
Sorry to somewhat hijack the thread but is it possible to remotely reset the G4 Password via Telnet or Send_Command?
