TELNET commands?
I'm working on a module to commincate w/ a CISCO switch via a telnet and the first string I get form the device when I IP_CLIENT_OPEN is:
Although I was baffled by the HEX values I ignored them but while in WireShark snooping around the RX & TX during a PC session w/ the device I discoverd that the HEX values are TELNET commands used to determine session parameters. So the HEX values above actually are the device saying:
So after googling I found this: (commented out since I pasted in my code for reference)
So I looked at the responses from the PC during a session and tried to respond in kind via code when I recieved this string modified to shut down the echo but so far no joy. Is this possible via code? Since I'm not sure how the packet is actually framed by the master when it leaves I can't be sure what's actually being sent or how it's formatted.
Anyone ever try this or something similar with success?
Line 8 (08:27:24):: J.A.P AXS MOD-1 DEBUG (1): RX DATA STRING- "$FF$FB$01$FF$FB$03$FF$FD$18$FF$FD$1F$0D$0A$0D$0AUser Access Verification$0D$0A$0D$0APassword: " :DEBUG <2107>The string sent being the stuff between the double quotes. This device also echoes strings I send it 1 char at a time, some times 2 which I can deal with as returned strings but I would prefer not too.
Note: this translation may be different from the string shown.//Command: Do Echo
//Command: Do Suppress Go Ahead
//Command: Won't Terminal Type
//Command: Won't Negotiate About Window Size
//$FF = IAC (interpret as command) or extended options list //$FE = DON'T //$FD = DO //$FC = WON'T //$FB = WILL //$FA = START SUB NEGOTIATIONS //$F0 = END OF SUB NEGOTIATIONS //$F9 = GO AHEAD SIGNAL //$F3 = NVT BREAK CHARACTER BRK //$F2 = DATA MARK //$F1 = NOP NO OPERATIONS //$1 = ECHO //$3 = SUPPRES GO AHEAD //$18 = TERMINAL TYPE //$1F = NEGOTIATE WINDOW SIZE (* Commands Dec Hex Description ---------------------------------------------------------------- data All terminal input/output data. End subNeg 240 FO End of option subnegotiation command. No Operation 241 F1 No operation command. Data Mark 242 F2 End of urgent data stream. Break 243 F3 Operator pressed the Break key or the Attention key. Int process 244 F4 Interrupt current process. Abort output 245 F5 Cancel output from current process. You there? 246 F6 Request acknowledgment. Erase char 247 F7 Request that operator erase the previous character. Erase line 248 F8 Request that operator erase the previous line. Go ahead! 249 F9 End of input for half-duplex connections. SubNegotiate 250 FA Begin option subnegotiation. Will Use 251 FB Agreement to use the specified option. Won’t Use 252 FC Reject the proposed option. Start use 253 FD Request to start using specified option. Stop Use 254 FE Demand to stop using specified option. IAC 255 FF Interpret as command. *)
Comment: I've never had to manually write code to control something via real telnet. As it is I can't think of the last time I actually talked to a real telnet server.
For some strange reason, I love doing telnet.
I quite often use it myself. For example: I have a nice little routine that telnets into AMX touch panels when they go astray. I actually wish I could still do my old Netlwork Time module using the old telnet into NIST's ataomic clock. It had the most clever way of dealing with daylight savings time. The current incarnation of Network Time does not.
My string $FF,$FB,$01,$FF,$FB,$03,$FF,$FD,$18,$FF,$FD,$1F" I just responded with $FF,$FE,$01 (don't echo) to which it then relpies $FF,$FC,$01 (won't echo) which is still does and then I send $FF,$F0 (end sub negotiations) which I don't think is needed since I think a sub negotiation is a reply to window size for example where you include a size parameters. I then get another Password: prompt to which I then reply with the password.
So it still echoes and I still just deal with it but responding to the 4 telnet commands in some part did clean up and make the initial login in smoother for some reason. I was getting '% Password: timeout expired!' alot even though the password was sent straight away and obviously faster than I could ever type by hand during a manual connection which I wouldn't get unless I took a really took along time.
Hmm... that doesn't make much sense, but I believe it was the window size part that the device (an RSLink temperature probe) needed before it would talk to me.
