U-verse Timing
I've been working wit ha U-verse box and seem to have trouble with the timing. The direct channel entry times out before I can enter the channel. Anyone have a similar problem or have a solution?
    How are you sending the IR? If you use the SP send_command instead of using PUSLE, you can set the on time for the IR pulse to a shorter value with a CTON command to the port, which should get the numbers in faster overall.
  • davegrovdavegrov Posts: 114
    Dave,
    Good Question. I am using Cinetouch and I'm not sure how it sends IR. In one of the files you upload it does allow for changing of the CTON CTOFF and other commands. I'll have to check and see how it does it. Thanks
    Dave Groves
    DG Sales and Service
    Support
    Hey Dave, why didn't you call me? Pulse time, interpulse time, time after input, time after power are all adjustable in data.
