Account permissions
annuello
I've now got Meeting Manager (v3.0.26) ready to deploy and am allowing access to it for other staff memebers. I have an issue with how the permissions are set for various user roles. In my case I've created a "Technician" role. They have the following permissions:
I would like to see the Logging & Reporting option split into two seperate items. (Perhaps "Reporting" and "Log File Editing".) This would allow the widgets to work without providing write (or delete) access to log file entries.
Failing that, a permission model that supports None/ReadOnly/ReadWrite access would probably also work. I'd be fine with managing the extra complexity of such a change, but I can't speak for the whole RMS community.
Yours,
Roger McLean
Swinburne University
Global System Permissions Manage Users = no Configuration Settings = no Manager Systems = no Room Level Permissions Logging & Reporting = yes Manager Control Functions = yes Manager Rooms = yes Access Other Users' Appointments = no Scheduling = noMy main issue is with the Logging & Reporting option. If it is disabled the Lamp Hour & Source Usage widgets do not get populated with data. (They can still access the data, but have to dig down through SystemStatus->RoomName->Devices to get the data.) If on the other hand L&R is enabled, then the technicians also have permission to delete log entries. I've had to enable it so the LH & SU Dashboard widgets work.
Yours,
Roger McLean
Hi Roger & all.
Yes - this seems to be an oversight in the permissions structure. And it hasn't been addressed in 3.1.
I work with clients who need the read-only access Roger mentioned - ie "look but don't fiddle". I believe this feature should be attractive to virtually all RMS users.
On the wish-list for version 3.2 please Mr AMX?
Cheers
...Phil
It's now three years on - have there been any improvements with account permissions ?
I need to give our frontline support full status monitoring of our venues, but prevent them from making changes.
In order to give them status monitoring, they need to be given 'manage venue' rights, however this allows all sorts of editing.
Dave
If AMX takes my suggestion on board then such an API would allow us to provide whatever custom GUI we like to whomever. If this comes to fruition then I think my request for better account management may become rather redundant. If I want read-only access for a user, there is no need for them to have an account on the system at all since they don't need to change anything.
Roger McLean
I've already had to do some configuration directly in the backend SQL - bulk imports of venue data, records which hadn't been removed properly etc.
The big LCD status display output is something that had also crossed my mind as a desirable feature for any such monitoring system.
Dave
FYI ...
http://www.amxforums.com/showthread.php?7035-RMS-2020&p=48491#post48491
